Power steering cylinder seals Case IH 585 MFWD
   / Power steering cylinder seals Case IH 585 MFWD #1
Jrasband
Platinum Member
Southwest VA
Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
I thought I would put a post here to see if anyone can help me. I am looking for power steering cylinder seals for my tractor. I have found them on the cnh website and a dealer can get them for about $300, this is just for the wiper seals and main seals! I already bought a seal kit for a Carraro front axle through John Deere for $140 and some of the seals were right but the main ones are for a larger diameter shaft.
Is there a aftermarket supplier for Carraro axle parts or somewhere I can look to find these seals at a reasonable price?
Here is what I am looking for, numbers 2 and 3 in the diagram.
   / Power steering cylinder seals Case IH 585 MFWD #2
I find that searching for cylinder shaft, piston seals and related O rings by application (or even by part number) is all too often a waste of time. You're better off matching parts individually by style, shape and dimensions. Provided you have the old parts, or what's left of them, to work with.
I don't know what you have available in your location in the way of a supplier for such things. Very rarely do I go looking for O.E.M. seal kits. Sometimes the kits are wrong for your cylinder, some have parts you don't need, and they're always way overpriced. I have a place less than an hour's drive that has most any cylinder seal or seal related item on the shelf. Whenever I tear a cylinder down I gather up the parts I want to replace and go there.They measure all the parts and pieces, in ten minutes I have the new parts and am on my way home. I've been dealing with them for years and only once or twice did they not have what I needed. They do business by mail as well as over the counter. so if all else fails for you and you still need help I can give you contact information.
   / Power steering cylinder seals Case IH 585 MFWD #3
First off, that is a ZF axle from Germany, not Carraro from Italy. There are aftermarket parts for both manufacturers for many of the hard parts, but few steering kits for Carraro and practically none for ZF.
Anyway, the Deere 2555 uses an APL325 axle and the seal kit is AL70934, about $140 from most sources.
Following is aftermarket for $92.
Also, the Ford 5610 uses an APL 325 axle and parts are sold through New Holland individually
Orange Signal Trailer (A50121)
Orange Signal...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Knight 1040 Manure Spreader (A50774)
Knight 1040 Manure...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
2014 Ford Escape (A50324)
2014 Ford Escape...
4 Unused Montreal ST205/75R15 Trailer Tires (A50322)
4 Unused Montreal...
