power steering conversion
   / power steering conversion #1
gbeerman
Satoh s650g
How big of a job and expensive would this conversion be? I have seen a few steering parts listed on ebay for instance that were somewhat pricey, but doable. I would assume it is similar to a car conversion which isn't too bad if you can get the parts.
   / power steering conversion #2
You can use a power steering pump ( if you have room under the hood) and ebay parts etc. I have watched orbital valves and steering cylinders for two years on ebay trying to decide if I was going to pop on one for a conversion on my Mitsubishi. In the end, probably the easiest conversion is this http://www.tractorbynet.com/forums/customization/138014-power-steering-90-minutes.html Quick, easy and relatively cheap....probably the way I will go when I finally do it.
That is a great link. Thank you very much, and the price of 425 is reasonable, I have been seeing used stripped parts being sent out for more than that. I appreciate your taking the time to look that up. Tell you what, when I pull down the motor and go through the tractor this fall (if I can wait that long), I will give you an update on how it goes!
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
