Power Shuttle Transmission Question...
   / Power Shuttle Transmission Question... #1
WesternMN
Bronze Member
Western Minnesota
None
My tractor (Kioti RX7320) has the hydraulic power shuttle transmission. When doing a lot of back-and-forth such as moving snow, I've been using the gas pedal to adjust rpm on the fly, reducing rpm to idle when switching from neutral to forward or reverse. What I'm wondering is, is this transmission designed to be shifted in and out of gear while running at higher RPM? Can I set the hand throttle to a higher rpm and leave it there while changing direction? Or are you supposed to always reduce RPM to idle before engaging forward or reverse?
   / Power Shuttle Transmission Question... #2
You can move between forward and reverse at higher RPM's. I do it all the time. I don't do it with hay equipment hooked up. :)
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
2020 Case CX245D SR Excavator (RIDE AND DRIVE) (A50774)
2020 Case CX245D...
John Deere 1023E (A50120)
John Deere 1023E...
Erie Industries GF480 Rolling Seperator (A50121)
Erie Industries...
2021 John Deere TS Gator (A50121)
2021 John Deere TS...
Truck Flatbed (A50121)
