Power shuttle transmission fault code - NH TN95DA 2008
   / Power shuttle transmission fault code - NH TN95DA 2008 #1
rogersavoie
Bathurst, NB
NH TN95DA
I Have a 2008 New Holland TN95DA tractor and the following Power shuttle transmission fault code appears:
-3 quick flash
-pause
-8 flashes
-pause
-2 flash
-pause
Can someone tell me what is this fault code and how to fix it ?
Thanks,
Roger
:confused:
   / Power shuttle transmission fault code - NH TN95DA 2008 #2
Roger, here is what the code 82 means:
Causes-1. Hydraulic oil pressure switch to 5 or 12 volts. Short to ground or open circuit between pin 31 on the ECM #2 connector plug and the pressure switch.
2. Oil pressure switch faulty.
The transmission dump valve will fluctuate for the first 30 seconds after startup. Code will register in ECM memory.
Likely solution- Look for disconnected plug wire on pressure switch or replace pressure switch and see if error goes away at startup.
You need the diagnostic tool to clear the fault code from memory.
Diagnostic tool is available from Case New Holland P/N: 380000282 approx. $420.
Also, sometimes used on Ebay. Old P/N: 294084 old tool, but useful for code reading and recalibrating.
Tanks Tractor Tech !
This is a much better answer that when you ask question to New Holland (your dealer is the one that is qualified person to answer your questions, bla, bla, bla). I even wonder why they bother answering.
I love my NH Tractor, but our local dealer went out of business ans I don't know how to get service now. NH America gives us no alternative, such as contracting the service to local technician.
Good tractor, but poor service from NH.
I'll try with e-bay for the disgnostic tool.
Roger
Hi,
I bought the presure switch, but now, I would like to know exactely where it is located.... There seems to be a few different swithch that all look alike.
Thanks,
Roger
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2012 Chevrolet Equinox 1LT SUV (A50324)
2012 Chevrolet...
2018 JOHN DEERE 310SL HL BACKHOE (A51242)
2018 JOHN DEERE...
