Power rake project
/ Power rake project #1
Zick
Platinum Member
WI
BX 2350
I'm working on designing a Power rake (Aka Harley rake) for my Kubota BX2350 and needed some double checking on my setup.
I decided to go with a hydraulic motor vs PTO gearbox.
I wanted to keep the drum RPMs around ~250.
I picked out a 3.15 cu in motor that with 3.7gpm I should be seeing 271 rpms. But I wasn't sure if I would always get a true 3.7gpm so I put in an 80% efficiency which drops me down to about 3gpm and 220rpms.
Here is the motor I was looking at: 3.15 cu in DYNAMIC BMRS50H4KS HYD MOTOR
I was also thinking about running the hoses (3/8") up to the loader controls and using the FEL level to run the rake until I get around to putting in some rear remotes.
Is there anything I need to worry about with using the FEL remote?
/ Power rake project #2
If you use the FEL to run the Power Rake, which circuit will you use for the motor on the rake?
The lift circuit or the curl circuit.
Some curl circuit have regen and could cause you problems.
Do you plan on holding the lever or use bungee cord to lock in place.
Do you have remotes.
Does your FEL valve have PB.
You could use a true 3rd function to run your Power Rake.
I guess I didn't realize there would be a difference between the lift and curl circuit.
I was just planning to hold the FEL level for the time being.
No remotes right now, but might look into getting Kubota factory rear remote.
Not sure what a PB is for the FEL valve?
Is this the 3rd function your talking about? 3rd function auxilliary hydraulic kits for all brands of tractors and loaders! purchase online, free shipping within 1,000 miles!!
If so, I would probably just get the factory rear remotes as I believe it's about 1/2 the cost of this kit.
Thanks for your help so far. :thumbsup:
Apparently it sounds like both circuits have a regen feature. :(
http://www.tractorbynet.com/forums/kubota-owning-operating/233590-bx25-front-plow.html
Guess that means I probably shouldn't try using the FEL circuit. Oh well, I was trying to save some pennies.
EDIT:
After reading this thread: http://www.tractorbynet.com/forums/...26-bx25-fel-valve-curl-detent.html?highlight=
It sounds like I could still use the FEL curcuit. I would just have to make sure the level is pushed pasted the detent.
Q: Why couldn't I just plumb it so that using the Level in the down position (raising the bucket, no regen) runs the hyd motor in the correct direction?
I really only need it to spin one way (would have been this way if using PTO) but being hyd gave me the option to reverse it too.
EDIT #2
Whoops, ignore my first statement. I thought both circuits had regen but I had misread. Only the curl curcuit has the regen feature. The lift circuit just has the float feature which as long as I use put it into this mode won't give me any issues.
Sounds like this will work after all if I use the lift circuit. :)
/ Power rake project #5
You can use the curl work port that tilts the bucket up. and lock the lever down.
They make a lever or solenoid motor spool valve that if the lever is in detent, you will have constant supply, or a solenoid with a switch that will switch the the solenoid to run fwd or reverse.
Just depends on the about you want to spend to get the job done.
I would think that using the lift circuit and using the lift fuction to spin the motor correctly would be the simplest because I could just keep my hand resting on the level to hold it down.
But I'm not against looking into alternative options.
Got any links to these solenoid spool valves?
Sorry, hydraulics are not my specialty.
Btw, do you see any problem with the hyd motor that I selected?
/ Power rake project #7
Zick,
Not trying to second guess you here but with the hydraulic drive you are talking about you will generate around 3.5 - 4 HP while with the PTO you would have 18 - 20 HP available. I think you will be very disappointed in how little torque or work this rake will do with the proposed hydraulic drive.
Zick,
No problems w/ second guessing, that's exactly what I'm hoping people will do is to make sure I'm not calculating this wrong.
I ran some calculations and figured that with about 17hp pto that I would be making about 360-432 in lb torque at 540 rpms. While reducing the speed in half to 270 I would double the tq to about 720 to 864 in lbs.
With a 3.15 cu in hyd motor and 3.7 gpm I would have 271 rpms and 1003 in lbs of torque. But I dropped the gpm down to 3 just to factor in for decreased efficiency and came up with 220 rpms and torque should stay the same unless I'm mistaken here.
I got my hyd motor calculations from this page: Hydraulic Motor Calculations | Womack Machine Supply Company
/ Power rake project #9
Zick
Formula I have for figuring torque is torque (in lbs) = HP x 63025
RPM
17 x 63025 = 1071425 / 540 =1984 in lbs torque
the reason I questioned this in the first place is I figured pump HP by taking 3.7 GPM x 2500 PSI = 9250 / 1714 = 5.4 HP to drive the hydraulic pump.
I might be way off base on my PTO torque findings. Trying to double check them now.
I got my PTO in lb calculations from this equations, see post #3 http://www.lawnsite.com/showthread.php?t=250005
you take the engine torque rated at x rpms then take the pto rpms and divide it by x(engine rpms) = gear ratio.
Take gear ratio and multiply that by engine torque which will result in PTO torque minus parasitic/drivetrain losses.
Torque curve from this chart, post #82
http://www.tractorbynet.com/forums/hydraulics/239712-bx25-mid-pto-pump-bust-3.html
In my case, I see I make 30 lb ft at 3000 rpms.
540 / 3000 = .18
.18x30=5.4 ft lbs
5.4ft lbs = 64.8 in lbs at 540 rpms. Cut that in half to 270 should result in 129.6 in lbs of torque.
Zick
RPM
Well it looks like you might be correct. Glad I asked. I did rerun some numbers w/ bigger pumps to get closer to the same torque rating but the speed would have dropped down to around 120 rpms which is probably too slow.
/ Power rake project #12
I should ask, is the power rake for the front or back?
If you had 10 GPM for a 10 cu in hyd motor, it would run at 231 rpm. Torque 4,777 or 398 ft lbs
The hyd pump takes about 21 HP to pump 10 GPM and a pressure of 3000 psi.
With an 85 % efficiency, the 21 HP from the pump would give the hyd motor about 17.85 HP.
If you have more GPMs, you will have more rpms.
I just noticed the flow on your tractor.
Hydraulics:
Type: open center
Capacity: 3.1 gal [11.7 L]
Total flow: 6.3 gpm [23.8 lpm]
It's for the rear.
The total flow isn't what's available at the FEL ports from what I've read, only about 3.7gpm and it looks like the factor BX7326 rear remotes only provide the same 3.7gpm.
I've thought about getting a PTO pump but then I would have to have some kind of oil tank, filter, etc as well and then it get more complicated and cost prohibited.
So at this point, it looks like I'm going to have to go back to the PTO gearbox setup, too bad. :(
/ Power rake project #14
I wanted one on the fel of my 1026r but came to the same conclusion that it wouldn't have enough power to do any real work. I am going to build a pto unit too.
Even thought I ended up going with a mechanical PTO driven rake, I just found this video of a guy who build one using a rear PTO pump. It's pretty large but seems to work well.
https://www.youtube.com/watch?v=bkt7qMbsiwk
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
Deere 333G (A53317)
Deere 333G (A53317)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2020 CZ Engineering CZ15KP 26ft Pole Trailer (A59230)
2020 CZ...
