Power rake for 2210.....
   / Power rake for 2210..... #1
Anonymous Poster
Epic Contributor
can anyone recommend if these work well? Thanks
   / Power rake for 2210..... #2
Power rakes work great. But the problem will be to find one to work on your tractor. Many are hydraulic drive which requires usually at least 9 gpm and they are heavy. Others are PTO driven which are even heavier and most have a Cat 2 drive line. Weights in the range of 900 lbs. - 1300lbs. plus is not uncommon. The little 2210 doesn't have enough 3-point capacity and it lacks high flow hydraulics. They are also very expensive. Look around hard and you may find a PTO driven one that may work with your tractor, but it will cost you....
   / Power rake for 2210..... #3
Glenmac makes the T5 which would probably fit. Needs 16-22 hp so your pretty good there. Weighs 550 lbs; I'm not sure of the hitch capacity of the 2210? These things are $$, but do a very good job. Oops, that's Glenmac.
Swict Q.A 60" Bucket (A50121)
Swict Q.A 60"...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
