Power Pole
   / Power Pole #1
RedRocker
Veteran Member
Bowie TX
Kioti CK30 HST, dual remotes, FEL.
About how tall are power poles?
   / Power Pole #2
Huw much does a hen weigh? Sorry- couldn't pass that one up. /forums/images/graemlins/grin.gif
   / Power Pole #3
Many different heights, depending upon the application.
Sorry can't be more specific than that.
Ben
   / Power Pole #4
There's a log weight calculator over on the Forestry Forum Somewhere in between green and dry as the creosote would add some weight
   / Power Pole #5
Question was 'how tall', not interested in weight. /forums/images/graemlins/wink.gif
Strange question however. Maybe we'll learn more about what is behind the partial question. Must be more to it.
   / Power Pole #6
</font><font color="blue" class="small">( About how tall are power poles? )</font>
Are you talkin' about the 30-footers or 40-footers? /forums/images/graemlins/grin.gif
Actually, I believe if you are talking about a drop to an electric box, it has to be at least 13' 6" but I always shoot for at least 14' off the ground. I think the main pwer poles are different sizes, but I bet if you are really interested, a call to the engineering dept. of Wise Electric Coop could shed some light on what they normally use.
   / Power Pole
Yep, the pole that my power terminates too. It's roughly as tall as my trees and I was thinking about building some kind of observation tower in the distant future.
   / Power Pole #8
I helped my brother load and haul two 30' poles he bought used from the Navarro County Electric Co-op. As for the pole on which our power terminated and on which the meter and master breaker were mounted, the Navarro County Electric Co-op required a 16' treated pole, minimum diameter on the small end of 6" and installed 4' in the ground and 12' above with the weatherhead even with the top of the pole, 2" galvanized pipe or conduit connecting it to the meter base mounted at "approximately" 6' in height.
   / Power Pole #9
</font><font color="blue" class="small">( Yep, the pole that my power terminates too. It's roughly as tall as my trees and I was thinking about building some kind of observation tower in the distant future. )</font>
Okay, now I'm confused... (nothin' unusual). /forums/images/graemlins/blush.gif
Do you mean a pole with a transformer on it, or a pole that's a drop from the transformer? My pole at my house has a transformer and a drop to the meter and a main breaker down at the 6' level. I believe the pole is 30' tall with about 6' in the ground so it's 24' feet above. Is that the arrangement you have? I'll check my pole tonight by eye-balling the pole in comparison to my house to get a more accurate guess-timate.
   / Power Pole #10
You know that voyureism is agin da law..... /forums/images/graemlins/grin.gif
2025 LandHonor LHR-CIA200 200lb Cast Iron Anvil (A49461)
2025 LandHonor...
Set of AG R4 Wheels and Tires (A51039)
Set of AG R4...
2008 New Holland B110 MFWD Loader Backhoe (A51039)
2008 New Holland...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
