Power of the PT
   / Power of the PT #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Well, love it or hate it, here are some results of roughly 8 hours of work. A before and after picture. Slope is around 22 degrees, with chunks that hit 30 or so... Besides the slope ability, I really like the turning radius and the front mower. Man it is an amazing machine when it works...
it is raining, so I am practicing welding... In the rain.. what the heck, no one liked the way I mowed ;-)
Carl
   / Power of the PT #2
Carl
That's one thing i learned when moving to this area. If you wont do it in the rain then you may never get it done.:)
   / Power of the PT #3
That's certainly an impressive Before >> After set of pictures... :)
I'm glad to hear that you're still impressed with the PT, despite all the minor problems you're having with it... :):)
   / Power of the PT #4
Amen! That's rule number 1 in the PNW!
   / Power of the PT #5
Carl
I finally got the pictures download.
I said "Holy Crxp!", my wife said, "What?". "Look what that guy down in Woodland did with his BIG pt".
   / Power of the PT #6
I'd say that is a pretty darned impressive set of tree munching pictures :D That PT's very powerful for it's size and manouverability
   / Power of the PT #7
That is generally how I work... Welding lesson #1 of this weekend: shut the valve on top of the bottle when you are done (full bottle of argon disappeared overnight !#%&^. And airgas isn't open on the weekends to get another bottle.)
   / Power of the PT #8
Did you ever spray soapy water on all the fittings from your regulator or flow gage to the back of the welder? This procedure will prevent this from happening. Turning off the main valve, and bleeding the regulator is standard practice. You probably wonder how I know this. I did the same thing a long time ago. I am using STARGON for the welding gas. Has a little bit of O2 in it.
   / Power of the PT #9
I think it is one of the learning lessons all welders go through...
Just FYI, there are several different STARGONs. Make sure you get the one that matches what you intended to weld.
e.g. Stargon CS for carbon steel (contains O2)
Stargon SS for Stainless Steel (contains N2)
All the best,
Peter
   / Power of the PT #10
All the best,
Peter
I use the Argon-CO2-Oxygen mix. CS
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2018 John Deere 8370R MFWD Tractor (A53342)
2018 John Deere...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2021 JOHN DEERE HX14 LOT IDENTIFIER 14 (A53084)
2021 JOHN DEERE...
