Power of 9n hydraulics
   / Power of 9n hydraulics #1
Anonymous Poster
Epic Contributor
To be sure I dont overload... what is the approximate weight limits on the hydraulics of a 9n?
Ken H.
   / Power of 9n hydraulics #2
You won't "overload" the hydraulics. Before you reach the limit, it won't lift anymore. If it is in good condition, you will lift a lot.
I assume you mean the weight limit on the 3-point hitch, not really the 'hydraulics'? Your hydraulic system should be protected with a bypass valve.
The answer will depend on where the weight is - the farther back, the more leverage, so the less you can lift.
As you can tell, I don't have a real answer for you, but hopefully some to think on. /forums/images/graemlins/smile.gif
--->Paul
   / Power of 9n hydraulics #4
I think at about 700 lbs. it will start to lift the front wheels off the ground, YEEEHAA power steering on a 9N LOL.
   / Power of 9n hydraulics #6
That low lift weight capability is due to the 'weak sister' hydro pump that kicks around 1200-1500 psi and 2.9 gpm..
Soundguy
2015 Ford F-450 Flatbed Truck (A51691)
2015 Ford F-450...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2015 Skyjack Scissor Lift (A53117)
2015 Skyjack...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
90007 (A51694)
90007 (A51694)
