Power loss under load..
   / Power loss under load.. #1
2TonCommon
Kitsap County, WA
Mahindra 2816 HST
Greeting all.... I need your help. I've got a Mahindra 2816 HST with 200 HRS on it that just can't seem to stay in the power band under load. I've changed the fuel filters twice, bled the air both at the fuel filter and at the injector banjo-fitting (also twice), installed a new OEM air filter, drained the fuel tank and blew it out w/ dry, compressed air and have religiously followed all the other Mahindra maintenance requirements.
Despite all of that, when I go to re-grade my driveway with a box scraper (about a 10% grade) I'll be at 3000 RPM in low range (and 4WD but not w/ the rear diff locked) with the box less than 1/2 full, headed up hill and about 1/3 of the way up, the engine will suddenly lose power and the RPM's will drop to between 1800 and 2000. If I raise the 3 point and let go of the gravel the RPM's will go even lower yet for a few seconds while the hydraulic pump works, then the engine will come back up to full RPM. I realize the first thought is that I'm overloading the engine and causing the problem myself. However, last year this tractor had absolutely no problem tackling the same situation as above and the box scraper was overflowing with wet gravel. So I KNOW this tractor can do what I'm asking of it.
This sudden drop in power also happens on occasion when I'm in medium or high range and try to go full throttle..... it will bog, drop RPM's then recover. I've worked on gasoline vehicles for over 45 years but have very limited experience w/ diesels. My gut is telling me this is a fuel starvation problem but I honestly don't know how to go about figuring out which component is the bad-actor. Any help or insight will be appreciated.
   / Power loss under load.. #2
I think your gut is right. Fuel starvation.
My Yanmar came with plastic drill shavings in the tank that would float around and block the fuel outlet causing nearly the same thing.
Since you've already cleaned the tank, you can 'probably' eliminate that as an issue.....so look elsewhere.
Is the tank cap vented ? Could it be on so tight you're getting a vacuum in the tank ?
IF have a plastic fuel filter housing, and can see it when this happens, see if it looks like it is trying to cave inward ( Mine did.....that was the give away to look at the tank ) as the pump sucks fuel.
Also, IF you have a booster pump ( you should hear it run when you turn the key to the "on" position, but engine not running ), make DANG sure to check and see if there is a filter in it. I have a Mitsubishi dozer that suffered the same problem....changing main filter did nothing. Finally got to reading the parts book and found an "element" in the back of that little booster pump. The back of the pump housing twists off, and there is a filter about the diameter of a 50cent pc, about 1 1/2" tall that gets the crud from the tank FIRST, and when it's blocked up, RPM goes to pot when you load up the engine.
AND the booster pump may not be working either ( I just looked online for a parts breakdown http://www.duntonfarms.com/tractors/Mahindra_2816/2816_parts.pdf and it does appear you have a booster pump. )
Look for all the simple stuff first.. and that is most likely the problem......barring that, you may have injector pump problem or a governor problem.
   / Power loss under load.. #3
Fuel restriction. Somewhere something is being sucked in the way during high fuel usage.
   / Power loss under load.. #4
I am having he same problem . Found what looks to be plastic drill shavings in the top of the fuel filter and in the line coming from the tank. I drained the tank and changed filter blew out feed line. Worked good for a while but I must not have got all of it Looks like I will be pulling the tank out to clean.
   / Power loss under load.. #5
Suggestion-
Drain fuel out of tank as much as possible and rig up a rigid tube on a shop vac and suck the debris out of the tank
May work :confused3:
   / Power loss under load.. #6
I was having same issue with my tractor and it ended up being a small piece of plastic that came off a plastic fuel can nozzle from filling. Mine was an easy fix at the filter,pulled a screw out of the housing to get to it. http://partstream.arinet.com/Image?.../www.hartleyenterprisesllc.com/pages/OemParts , my guess on yours will have to pull 2/3/4/5 out and it will be in there. Make sure line back up the same way took out so your fuel cut off will work right.
   / Power loss under load.. #7
Don't ask me how, but I have had 2 2615s that I found a restriction in the fuel line between the fuel pump and the banjo at the injection pump. I just disconnected it at both ends and blew it out. Quite a bit of black crap came out and it solved the problem. Just how it got there after the filter, I don't know. I would give it a try.
   / Power loss under load.. #8
Had it happen on my JD 4010 one winter. Turned out to be globs of wax mostly blocking the outlet line from the fuel tank. Had to siphon off the fuel and then use a fish tool to get the globs out.
Wax will drop out of ULSD if the winter nights get below 10 F.
Ralph
Thank you all for the very good ideas and suggestions. I will take a turn on these over the next few days and report back any success.
   / Power loss under load.. #10
I don't have a large fuel-supply tank set up (just yet),
I'm still using two new 5 gallon yellow fuel containers to refill the tractor tank (the .30/gallon HWY tax really hurts too).
The point: I was digging little flakes of plastic from my 3016 water separator/filter and traced them back to the yellow fuel containers; they had a lot of left-over plastic molding flakes in them. You may look inside the plastic and not see them but they are dangling on the seams like the leaves on a sweet-gum tree....:mur:
I also ran the fuel I had through screens and cloth filters several times before going into the tractor; can't trust what comes out of the commercial pumps because we citizens here in Oregon, cannot be trusted to fill our own fuel tanks at those retail pumps.
44509 (A51692)
44509 (A51692)
John Deere TS Gator (A50121)
John Deere TS...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2012 Crane Carrier Low Entry Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
3pt 6' Box Blade (A50121)
3pt 6' Box Blade...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
