Power going uphill
   / Power going uphill #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So in the land of paranoia...
I have been hearing a funny grinding noise coming from one of the pumps. I swear it had not been their before, but that is pretty typical of me to think this and it not be true.
So going up a hill today, the tractor bogged down. It has been a LONG time since I went up this hill, and it is very steep (30 degrees). I remember just running up the hill, no bogging down.
But what I am thinking is that I am really full of crack. That if the engine is bogging down then at least the power pump to the wheel motors is in great shape, and that the motors are in great shape otherwise the engine would just rev and I would just not get up the hill.
Just making sure on this.
Carl
   / Power going uphill #2
If a bearing was going south in the pump, that would cause this. Also, if a bearing was going in the engine, that would cause this. Either way, the bearing would overheat pretty quickly. I would think that you would notice something when looking under the hood while running the motor.
Hopefully it is just paranoia as you say. I get that way too sometimes.
   / Power going uphill #3
My experience is with the 1845 but I find that climbing anything over about 20 degrees requires a "downshift"--backing off the treadle and slowing the ground speed to keep revs up without bogging down. Up to about 20 degrees I can keep the treadle floored going up a hill.
UNUSED FUTURE FT-ZP210 20' X 30' ALLSTEEL GARAGE (A57193)
UNUSED FUTURE...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
2006 iDrive...
2019 Deere 310L (A53317)
2019 Deere 310L...
2017 HAMM HD14i SMOOTH DBL DRUM ROLLER (A52707)
2017 HAMM HD14i...
2020 CAT 308 (A53317)
2006 Toyota 7FGU60 Forklift (A55973)
2006 Toyota 7FGU60...
