Power Beyond
   / Power Beyond #1
gbrig8364
I am wanting to buy a JD 1760 planter that requires hydraulic power for the vaccum pump. Can I run the pump with a power beyond kit or do I need a separate SCV on my JD 4450? I only have 2 SCVs now and one is required for up and down and one for the markers. What does a power beyond kit allow you to do? Thanks.
   / Power Beyond #2
Welcome to TBN:D
The PB kit supplies a constant flow of oil to implements like logsplitters and backhoes that have their own control valves. There is no ON/OFF to it-if the tractor is running then oil is flowing.
I am not familiar enough with the planter to answer specifically, but it sounds like you need something with a control valve?
I separate valve can be plumbed to the PB line to add a new SCV.
2002 Enclosed Trailer (A52377)
2002 Enclosed...
2017 Ram 4500 Bucket Truck (A53473)
2017 Ram 4500...
2018 Ford F-250 4x4 Crew Cab Gooseneck Flatbed Truck (A51691)
2018 Ford F-250...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
