OK, so my tractor has crappy controls and I am updating it for multiple reasons. My current FEL valve has no power beyond. It has only 2 lines going to it, a pressure from pump, and a return to tank with a internal relief valve. My new remote joystick valve came with 3 lines, and I assume from pictures on the web and the type of fitting installed that one of the three hoses is going to be for a power beyond. 2 questions...
If I don't want to use a power beyond circuit, can I just plug off the power beyond Bushing/fitting ?
Second question, If I decide to use the power beyond, can it be used to add just remote hook without any valves for a backhoe or log trailer, meaning that if nothing was plugged in would it dead head and blow up something? Would I need some kind of switch or bypass? they would not always be plugged in meaning that circuit would not have a return to the tank with nothing plugged into the remotes. Here is the new control valve, I bought it sight unseen and it has no instructions. If I need something to divert to the tank when nothing is plugged in to the power beyond, what would that be?
