Power Beyond - Operation Question
   / Power Beyond - Operation Question #1
Spudland_Dave
Veteran Member
Maine
Deere 3520 Cab, Deere F935
With all this talk about power beyond it brought up a question I have...
Is it possible to utililize the PB while the tractor is in motion? I'm guessing on a PR equipped machine its no problem but how about a eHydro?
For the sake of arguement I'll use this example.....I install a valve bank with a few sections in it in the PB loop....couple go to cylinders and on one spool I have a small hydraulic motor which turns a small conveyor belt......all of which I would be using while the tractor is in motion. Is that a possibility?
   / Power Beyond - Operation Question #2
I's say yes - at least on my JD 3320 eHydro - AFAIK the PB lines simply provide uncontrolled access to the basic hydraulic flow and then the tool(s) need their own control valves.
   / Power Beyond - Operation Question #3
The hyd. pump is pumping all the time when the engine is running. Standing still or when in motion, pump is running and Hyd's is working.
I'm thinking your question may have another side to it.
   / Power Beyond - Operation Question #4
Generally the PB is used to run rear implements. Log splitters, back hoes, etc. You could for instance, run a shute diverter on a rear snow blower with it and in this case you could change the direction of the shute as the tractor is moving.
So the answer is yes, in fact, I have reached around while going forward to raise the bucket on my BH.
Rob
   / Power Beyond - Operation Question #5
Right...Remember Dave that the hydrostatic transmission has it's own pump driven from the crankshaft on the engine. The power steering and implement pump is a separate system. The only thing "common" is the sump.
So the short answer to your question is Yes, absolutely.
   / Power Beyond - Operation Question #6
I have reservations about the actual "capabilities" of such a configuration.
I do not disagree that it would NOT work - I think that yes; you would have hyd flow and function.
However, I do not believe that you would have sufficient flow (while the tractor is moving to effectively power very much).
Much depends upon 1.) How fast the tractor is moving (hyd demand) 2.) The dimensions of the valve body and the total hyd demand.
Whenever, I attempt to do any "intensive work" with my 110 when moving at a significant speed i.e. heavy loader work or run the hoe circuits - the tractor will drop speed - markedly! I have to back off the direction pedal in order to maintain hyd function to either the loader or the hoe.
I can nearly stall the machine by pulling the stabilizers or dipper, etc. when the tractor is in motion. When a cylinder ends travel and it goes to bypass - the hyd motor - will drop speed dramatically.
So, I would question how much "actual work" might be functionally possible with a tractor that has half the gpm flow rate of a 110? I can readily envision the moment you pull the PB circuit open (with the tractor in motion) and the hyd motor going to bypass.
AKfish
   / Power Beyond - Operation Question #7
I'm not sure Fish. I think there's a difference between the 110 and the compacts.
Also flow rate is not power. I learned that when I went to more flow rate with the same implements. Power = pressure and as long as the pressure is up the power is up, things just move slower at less flow rate.
On the compacts there is very little if any change in rpms. I've raised a full bucket while going down the road at a good clip.
Rob
Thats the piece I was not thinking about...I knew there were 2 "zones" in the hyd. system, but I didnt know where the line was drawn...so other then the excess HP requirements if I were to use both the tranny & PS/Implement side at 100% both.. I'm good to go.
Awesome...
I was thinking for some reason that ground speed & force would suffer if I were to utilize the PB to its full extent in a worst case senario..In the senario in my head, the "rolling force" is minimal and I could substitue the hydraulic motor for a monkey turning a crank if I could get a monkey cheaper then a hyd. motor...:laughing:
Rob is 100% correct...College was good to me :drink:, but I do remember my fluid power course...
Pressure = Force
Flow = Speed
   / Power Beyond - Operation Question #9
I'm not disagreeing or stating that there is a loss of pressure or power - not at all.
The loss would be sufficient flow and the speed at which any real work could be done by the circuit.
Therefore, the practicality of the theroetical hyd function that "inches along" is....
So, my question remains unanswered - in a real world application - what work would/could be accomplished...?
AKfish
   / Power Beyond - Operation Question #10
AKfish
AKfish,
The difference is the 110tlb has a much larger hydraulic system about 30 gpm at a maximum pressure of 3000 psi while having a relatively small engine at 43hp. So the hydraulic system is a major load on the 110. My 4520 with 60 hp has a 17 gpm pump running at a maximum pressure of 2500psi. This is what makes the difference in your case.
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
