power beyond on 3320 w/cab
   / power beyond on 3320 w/cab #1
tglass
Platinum Member
3320 w/cab
Has anyone else been told or found out PB is not available with the 3320 cab model? Just tried to order and got the non available with cab at this time reply. Maybe I don't know what to order and need help. Trying to run a hyd. motor and cyl. at the same time without loss of the 3-pt. I've also been told the excess heat on the system could hurt the e-hydo without it. Is this true if using the 3rd svc to run the motor, and is there another way of doing it?
   / power beyond on 3320 w/cab #2
I am pretty sure you can still get it.
The PB kit is usually linked to the use of a backhoe. The BH is incompatible with the cab option so that might automatically eliminate the PB option. I have run into a few items like that.
   / power beyond on 3320 w/cab #3
There were some earilier post that stated that the BH is not available for the cab model. I believe by not alowing a power beyond option is JD's way os skirting the liability of someone placing an after market BH and crushing the cab of the tractor. I am sure that if you want you can pipe it yourself and power implement. But rest assusred that deere will not support you if you do something to the tractor.
   / power beyond on 3320 w/cab #4
Oh I bet you can order it. If you are using the configurator to get the part number, just start it again without the cab and get the right option/part number for it.
Your salesman should be able to order it.
The configurator is just a bit limitted. I have had this happen before and just found the right number or had my salesman find the right number.
It just didn't occur to the person setting up the site that there are other attachments (like log splitters) that might want the PB, other than the BH.
The configurer has the option w/out cab but not with. Dealer said he contacted J.D. and the option is not available yet. Will contact me when avaliable, but no options in the mean time. Thought about an add on, but didn't want to loose the ease of installation or tractor warranty if something happened. Dealer told me the system uses the same pump as the e-hydro and with the added extreme heat by using the loader hyd. to power the pump it could. Maybe call J.D. Customer Support tomorrow and see if they can help. What if I only added a log splitter?
   / power beyond on 3320 w/cab #6
Not sure what you were trying to say in your post...
but the hydrostatic transmision has it's own pump (at least that's usually the case with JD).
There are a few of us on the site that have log splitters that run off the PB on our 3x20 tractors. No problem, except JD decided to plumb the PB kit so that if you plug something into it, the rock shaft is dissabled. Pretty short sided if you ask me.
Talked with J.D. customer support friday. They said the power beyond is not available for the 3320 w/cab at this time. Possibly in the near future and could not say why the pb kit for a 3320 w/out cab wouldn't fit other than possible hyd. line bends, and connections. They also said even w/out the cab you should not loose the 3-point hitch or rockshaft use. A main question since I need all three (one motor, one hyd. and the 3-pt). Is there a aftermarket way to hook this up and what about the difference in opinion about the rockshaft working or not with the pb attached?
   / power beyond on 3320 w/cab #8
Ah, you are probably right about the hard lines or the bracket not fitting with the cab. It is a pretty extensive option (the cab I mean).
I am do to swing by my dealer in the next week and he has both configurations there so I will take a look at them to see what might be the problem.
Oh, one thing, the SCV for the loader is in a different place on the cab version,
so yes the lines would be routed differently... bummer.
2013 Nissan Pathfinder Multipurpose Vehicle (MPV) (A51694)
2013 Nissan...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
2025 12V Diesel Pump, Nozzle and Hose with Meter (A50323)
2025 12V Diesel...
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
377811 (A48836)
377811 (A48836)
