Power Beyond for New Holland TC25D
   / Power Beyond for New Holland TC25D #1
Dale EH
Mercersburg, PA
JD 750
I recently purchased a ~2000 model with a Great Bend 240 FEL, and I would like to add BP for to power my log splitter. The hydraulic pump for this tractor is rated at 7.1 GPM. The relief-diverter valve has been adjusted by rotating the spool position to the 10:00 position. My question is, which line is the best place to cut into to get fluid for the PB, assuring that when in operation, I will be sending all 7.1 GPMs to the splitter. Once the line is determined, I plan to install a single spool selector valve just to turn on the PB. (Which of course will turn off the flow to other areas of the tractor. I do not need to have the function of the lift arms or the FEL while running the splitter)
TEST BID LOT (A50774)
SKID STEER QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
SKID STEER QUICK...
SCAN FOR HAULING AND FINANCING INFORMATION (A51243)
SCAN FOR HAULING...
2002 INTERNATIONAL 4700 4X2 SEWAGE TANK TRUCK (A51243)
2002 INTERNATIONAL...
2014 Volkswagen Passat TDI SE Sedan (A50324)
2014 Volkswagen...
