Power Beyond for JD 790
/ Power Beyond for JD 790 #1
jmerritt1
Dunbarton NH
JD 790
Hello,
This is my first post, but I have reading posts from this site for quite some time. Its been very helpful.
I'm in need of a bit of advice. I have a JD 790 with a 70 FEL. I recently purchased a JD 7 backhoe to put on it. I purchased it knowing that I had to install the power beyond kit to my tractor. Its JD part number BM18005. Guess what....turns out that part is obsolete! I've searched everywhere for one and have had no luck. I have a search pending incase one pops up on Ebay, but I'm doubtful.
It doing some research, it appears like the kit was rather 'simple', so I am contemplating trying to build the kit myself. It looks like I need to tap into the supply side of the rockshaft and then plumb in a return to the rockshaft housing. I found a great post on anther site that seems like I could use stock hydraulic parts to build the supply and return lines.
My question(s) is relative to the connection to the rock shaft. The power beyond kit that JD used to offer hooked up to the rockshaft using a hollow screw and banjo connection on a hydraulic tube. It appears that I can get the hollow screw still (part M800853), but I need a banjo connection to a JIC that would fit the hollow screw. Does anybody know where I could get one? My plan was to connect to the rockshaft using the banjo to JIC, then use stock hydraulic hoses and fittings to create the power beyond lines. IS that a bad plan, or should it work? here is an image of the power beyond kit that I got from another post on this forum. PBlines%20a[1].jpgPBlines%20b[1].jpg
Appreciate any help that you can offer.
Thanks,
Jeff
/ Power Beyond for JD 790 #2
Since no one has responded I will try.
I needed a banjo fitting for my 1960's era Nuffield.
I was expecting to have a hard time finding one but the local hydraulic shop carried them.
Go with the hollow bolt to make certain you get the correct size.
This link will show you what is typically available.
Products | Green Line Hose & Fittings
Once when I could not get the correct fitting to attach to the banjo bolt I had a good welder with a TIG weld a fitting to the banjo fittng.
Dave M7040
1985 Mako Center Console Boat with 2011 HMDE Trailer (A61574)
1985 Mako Center...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
Towable Generator (A60352)
Towable Generator...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
84'' SKID STEER BUCKET (A61572)
84'' SKID STEER...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A61572)
2018 Roadtec...
