ptexer
- Joined
- Jan 26, 2011
- Messages
- 116
- Location
- Philippi WV
- Tractor
- farmall cub John Deere 310 Backhoe Loader Ventrac 4131
I have a John Deere 310 Backhoe loader. It has a closed center hydraulic system. Pressure line from pump goes and tees to the accumulator, and goes to power steering. The other part of the pressure line goes to another tee for Fel and on to the backhoe. The pressure line going into the joined 6 spool valves does not go directly in but goes into a tee there leaving a plug in one end of the tee. There is also a return lined plumbed the same way. I want to add another spool or two to run a thumb for my backhoe and possibly a woodsplitter. flow rate is 26 GPM pressure to 3000 psi. Most post are about open center system. Could this be as simple as plumbing closed center valves into the two plugged ends of the tees.
