power banks/jump starters battery questions
   / power banks/jump starters battery questions #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
My Kubota B7610 battery wouldn't fire my tractor, I suspect it was weak. So instead of dragging the charger and extension cord to it I just hooked up my HF Lithium Ion Jump Starter and Power Pack. And it worked :) :)
But that got me wondering - How do they rate these? The HF unit is "rated" at 12,000 mAh. I just bought a Samsung power bank for my Wyze camera (that draws 2 watts/hr) that is rated at 10,000 mAh. But I can't find the voltages these ratings apply to. Is the HF unit 12,000 mAh at 12 Volts? Is the Samsung 10,000 mAh at 5 volts?
Could my HF unit charge my camera for 3 days?
Could I tape 3 of the Samsungs together and jump start my tractor?
   / power banks/jump starters battery questions #2
Jump starter packs are designed for very high amp draws. USB battery packs are not. You'd blow up (possibly litterally) the USB pack if wires didnt melt or safety devices didnt trip. Many of the jump packs have USB ports on them though or will power a low draw 5v adapter fine.
   / power banks/jump starters battery questions #3
Oh, and USB is 5v, unless you deal with some of the funky quick charge protocols. Those do higher voltage. They will always rate things at the most impressive number though. So to get high amps or amp hours they will use the lowest voltage.
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2015 GMC Acadia SLT1 SUV (A50324)
2015 GMC Acadia...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
EZGO (A50324)
EZGO (A50324)
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
JLG MAN LIFT (A52472)
