bcarwell
I am putting in a concrete slab under my 40 x 15 foot roof overhang extension on my barn for some extra outdoor work room- not alot of floor load. Because I don't have a big concrete mixer and crew I'm thinking of doing it one section at a time, e.g. in four separate pours of 10x15 foot sections 4 inches deep. I'm around Austin TX with clay soil bed (e.g. drainage not so great but it will be on a well prepared bed with gravel if that matters. A few questions:
1) Would you attempt to tie the sections together mechanically with rebar or remesh and if so how ? I suppose I could make multiple slots in the form board starting on the bottom edge and extending vertically upward for rebar to extend through the form a few feet into the next section and guess the form would be removable on curing. Don't know how I'd do it with remesh other than sandwich it between 2x2 forms so the remesh could extend into the next section. I wouldn't think there would be a lot of shifting between sections though and wonder if tying is even necessary.
2) I'm figuring 50 cubic feet for a section. With a 3 cubic foot concrete mixer that would be 15+ loads. I'm guessing 5 minutes mixing + 5 minutes loading the mixer for each load or 10 minutes per load nonstop- probably more like 15-20 minutes per load including dumping. That would be 3-4 hours pouring for a section. Is that even doable (I don't have much experience with setup times, etc. but assume the "crew" could keep up with the pours and necessary screeding, etc. and would assume by the time the last pour is made it wouldn't be too late to start back at the beginning of the slab section for bull floating, trowel/finish work. Yes ?
3) NOTE: You may be saying "Why not order concrete for the whole job ?" As noted I have a small crew and don't think a concrete truck would hang around that long. Also I can do one section and wait a month or so before getting around to the next section.
4) And what would you do about the space between the sections ? Just leave the form board in place ? Or pull it and fill the space with what ? I don't really care about winning any beauty contests, just function.
Thanks for any advice, including "You are nuts".
Bob
Bob
