Pouring a ~900 sq ft Concrete Pad (basketball court)
   / Pouring a ~900 sq ft Concrete Pad (basketball court) #1
deezler
Elite Member
Southeast MI
Cub Cadet 7305, Kioti CK3510seh TLB
Well I figure I took enough pictures along the way that I might as well share this project I am just finishing up. Feel free to correct my techniques and methods however you want, keeping in mind that it's too late now, I think I did a fine job (first time doing flatwork!), and it's done now anyway. 🤪
Background: I had my 30x36' pole barn garage put up back in 2017. Back then materials were crazy affordable, didn't know how awesome I had it. Should have gone bigger on everything and pushed my credit to the absolute limit, but funds felt tight.
Inside the garage, I poured a 24" deep ratwall around the perimeter myself, did all the slab prep (level, compact, floor drain, 2" insulation, vapor barier, rebar, pex tubing for future radiant heating) and then was able to get the full 1,080 ft poured by a crew at ~5" thickness for just $3,500! What a bargain.
Shortly afterwards, I poured by own concrete sidewalk connecting the garage to my house, and a 42" wide apron out in front of the garage roll-up doors to avoid a harsh transition from gravel to the building interior slab. Concrete was just above $100/yard back then.
We always knew we would want a proper, large concrete pad out front of the garage as well. In the meantime it was good sandy soil that compacted well and drained quickly, though I did have to add gravel every now and then to avoid it being too muddy in the fall and spring freeze/thaw cycles. Other projects around the property consumed my brainpower and free time, and we got used to just living with a dirt basketball court. But then my son started playing on a team in competitive league play, and we knew it was time to get a proper half-court in place. So without overthinking anything, we dove right into it.
First step was leveling the area with my tractor, ended up removing a lot more material than expected to get things level. Used simple 2x4s for forms, right on grade. My trusty old plate compactor is occasionally my favorite machine, to be honest.
I knew I would do this pour in two pieces, to keep things manageable and keep half of the garage accessible as much as possible.
Thankfully I had a good stash of 20', 1/2" rebar sticks on hand still. I recently inherited a nice abrasive chop-saw from work, surplus that no one else wanted. Muuuuch better than using a hand-held angle grinder, I tell you what. I put my son and his neighbor buddy to work laying it out and tying all the intersections.
Tried a new concrete company in my area this time and was quite pleased with the service, quick availability and pricing. The drive let my daughter sounds the horn before we started pouring (scared the crap out of us all, way too loud haha)
Didn't get any pics of the screeding process but it was pretty rough going. We used a 20' 2x4 across an 18' pad; had to make a few passes. But thankfully the bullfloat did it's job nicely afterwards. My brother-in-law was kind enough to come put in some muscle with me, here he is applying the broom finish after floating.
My daughter enjoyed being in charge of keeping the pad wet for a few days until I could get the control joints cut.
Then I looked into concrete saw rentals (no way I was going to make 5 passes with a circular saw again, that SUCKS) and realized I might was well just buy my own saw to keep and have around for future work.
This Vevor machine works really well, it eagerly wants to rip itself ahead and down into the concrete. But it does tend to make your extension cords HOT and blow 20A breakers after every few minutes of cutting. Have to take some cool-down breaks and switch cords/outlets periodically.
With that, the first half of the pad is done. I wanted to take a break from doing this kind of work on hot summer days, but I knew I couldn't afford to lose momentum. Second half coming next....
   / Pouring a ~900 sq ft Concrete Pad (basketball court) #2
Looks nice. Doing concrete in Summer is brutal work. When are you doing the other half?
So then it was time for the second half of the pad. When laying this half out, I realized it would be a little closer to a driveway island than I was comfortable with. When we get any deliveries, guests or even lost folks who don't stop to check in, they come down and blast around this island circle that I have near the garage. Well I didn't want delivery trucks clipping the corner of my new concrete pad every time they circled around. So the island had to get smaller and a couple trees had to come out. But since I didn't want any stumps to contend with, I felled the trees by my preferred method - excavation. Somehow the backhoe slipped right into its mounts on the tractor in record time, must have been under 15 minutes to get it mounted.
Always nice to tell the tree exactly which direction to fall using the backhoe.
Then got the leveling done on 2nd side. Again, a lot more removed fill than originally expected!
The Blue Angels stopped by town, so had to take a quick break to hit the lake and partake in the show.
Ok back to forming and rebar:
15 days after the first half pour, we are pouring side two. It was shaping up to be a hot, full-sun day. So I got a little nervous when the concrete truck ran 40 minutes late to arrive.
But we got it all laid, screeded, floated, and brushed before the sunshine was too brutal.
I let the fam carve some memories into the corner of the pad
And two days later, cut the remaining control joints.
Pretty satisfying to get this sucker laid! More finishing work and follow-up in next post.
The longer I'm at my place, the more I want concrete everywhere!!!!
I hear you there. Concrete is aesthetically pleasing, so easy to clean, super sturdy for storage and any activities, etc. I can envision a future where I add additional outbuildings and have them all linked by concrete drives so I could shuttle stuff around with a little forklift, etc.
   / Pouring a ~900 sq ft Concrete Pad (basketball court) #8
Most importantly, it's "one and done!"
Yeah, as long as you do it right! Having old busted up concrete can be pretty awful, and it sure isn't easy or fun to remove. So I make sure not to skip on compaction and rebar.
Plus getting a slower cure is important. We set up a wifi-enabled sprinkler controller for this second half of the pad; it watered itself every 45 minutes.
   / Pouring a ~900 sq ft Concrete Pad (basketball court) #10
How much is finished concrete a yard up that way?
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
Year: 2006 Make: Ford Model: Econoline Vehicle Type: Van Mileage: Plate: Body Type: 3 Door Van; (A51692)
Year: 2006 Make...
1984 Utility 44 ft. Reefer Trailer (A53117)
1984 Utility 44...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
