Poulan Pro Riding Mower Reverse Problems
   / Poulan Pro Riding Mower Reverse Problems #1
Leon Wittner
Canyon Creek Mt, Gig Harbor WA
Kubota - L2800, Kubota RTV 900, Kubota ZTR 124Z
I have a 42" Poulan Pro Model #PPR204ST that will not go into reverse forward speeds ok but when I release the clutch in reverse it does not back up. Any one know what causes the problem and how to fix?
   / Poulan Pro Riding Mower Reverse Problems #2
Does it have a geared transmission or a wheel on a disc drive similar to a Snapper Rider?
Unknown has six speeds forward and one in reverse.
   / Poulan Pro Riding Mower Reverse Problems #4
Do you have to push in the clutch to shift gears?
I can shift without pushing the clutch I think but I always stop and push clutch in before shifting. The linkage was kind of corroded and I sprayed it with WD30 and the shift lever moves free but when I release the clutch in reverse it does not move.
   / Poulan Pro Riding Mower Reverse Problems #6
If it has a rubber tired wheel that spins against a disc, I have an idea of what's causing the trouble. If it has a geared transmission, transaxle, or hydrostatic drive I'm lost too. The following link should show you what the wheel looks like.
snapper rider drive disc - Google Search
   / Poulan Pro Riding Mower Reverse Problems #7
Either a bent shift lever or a broken reverse chain in the tranny.
   / Poulan Pro Riding Mower Reverse Problems #8
I see that Randy is a master service technician . Sorry for wasting your time. I'm out.
   / Poulan Pro Riding Mower Reverse Problems #9
I have no lever on my poulan pp14a42 riding mower, it has a pedal, and frequently won't engage to reverse, any ideas?
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
2007 GMC C8500 Altec AM650 Material Handling Insulated Bucket Truck (A44571)
2007 GMC C8500...
2012 FREIGHTLINER CORONADO 122 SD (A45333)
2012 FREIGHTLINER...
MIKASA MTX-70 PACKER (A45333)
MIKASA MTX-70...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A44789)
2014 Yale 3 stage...
2020 KENWORTH T800 DAYCAB (A45046)
2020 KENWORTH T800...
