I believe I have heard it called "Korv". Our potato sausage has ground beef...lean, not extra lean...(7#), ground pork (5#), ground potatoes (15#), salt (7 T.), pepper (2 T.+), allspice (2 t.) and 1 Lg. onion (ground w/juice...not saut馥d). This is all mixed extensively (in lg roasting pan) until all ingredients are fully mixed together and then "stuffed" into about 2# of beef casings...and yes it is boiled (45 minutes to 1 hour) and not fried. Note that we use the "middle" grinding disc as we like the potatoes ground a bit coarse. Also note that you need to squeeze the ground potatoes in a colander and dispose of the liquid before you add them to the mix.
All of these amounts can be varied to taste and each "batch" is always a bit different due to quantities of ground meat and the potatoes.
BTW...we use a very old cross section from a cow horn to stuff the final mix into the casing...we also have a cross section of an old piece of Tupperware...actually an egg yoke saver...that we used before we inherited a second cow horn (when two people are stuffing).
Also makes a good sandwich the next day with Swedish rye bread. Yesterday we only tasted a "sample" ring that is boiled to check the spice levels...then the rest of the batch is frozen and will be thawed and cooked on Christmas Eve. Each year's batch is always "the best ever"
I have added a few pictures from yesterday's event. Kind of shows the process...youngest grandson grinding (may be a second with grandson with DIL), one daughter squeezing liquid out of ground potatoes, another daughter and her husband stuffing, one of the final mix in the large roaster and one of a "ring" in the water starting to heat up for boiling the "sample" ring...and one of the two cow horn "stuffers" and the Tupperware poor substitute
Sorry if my recipe is a bit difficult to follow...probably should have put in a columnar form...feel free to PM me if you have any questions and want to try making some...I will have my WIFE reply
TMR
P.S. Sorry...had a bit of a problem with attachments...but they all made it...just two locations
TMR
