Post pounding new fence questions.
   / Post pounding new fence questions. #1
City Farmer
Platinum Member
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
Hi all.
I used the search function but could not find what I was looking for.
I bought a Shaver HD8 a while back at auction and have a couple questions on post pounding.
I live in Michigan and people are telling me to pound the post in big end in first. To me, that doesn稚 make much sense because I would have to tamp each post. I think the small end should go in first but I am worried a about the frost heaving the post. The posts are all 8.5?9 long cedar and the ground is mostly sand/clay mix with about 10-12 of topsoil.
1) Should I spray the cedar posts with oil or stain before installing?
2) Is the small or large end driven in the ground first?
Thanks,
Andy
   / Post pounding new fence questions. #2
Small end first, and a blunt (flat) cut, not pointed,,
If you hit a rock, the blunt cut will drive the rock down, rather than veering to the side, as a pointed cut would.
   / Post pounding new fence questions. #3
Small end first and you will not need to tamp anything. Pounded posts are the strongest posts because you are not disrupting a bunch of ground like you do with an auger. We pastured 13 acres a few years ago and none of the posts have moved. Have hit them with the mower before and they are SOLID. I live in Ohio. We had 8ft long posts and put 4ft in the ground.
   / Post pounding new fence questions. #4
Drive fence post small end down, just like they do when driving pilings. The ground will be compressed and the post won't move. The fence post is a miniature piling.
   / Post pounding new fence questions. #5
I've done the bigger end before and they are still solid, but like everyone else has said they will drive easier small end in the dirt and will still be solid.
Thanks for the input everyone, small end it is. :thumbsup:
The neighbors told me again yesterday I was crazy with the small end down because they will pop out and become loose in the winter frost. We will see what happens next winter.
2015 KENWORTH T680 (INOPERABLE) (A52472)
2015 KENWORTH T680...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
90018 (A48082)
90018 (A48082)
Two Engines (A50325)
More info coming soon! (A50323)
More info coming...
