Post Hole Digger
   / Post Hole Digger #1
HitchCL
JD
Looking for a quality Post Hole Digger
Id like it to be able to take larger augers to be able to work with large sono tubes for decks, etc.
I have priced out several different brands through local dealers and this is what I came up with. All of the prices include the machine, a 9" bit, a 12" bit, and a stand.
Shaver 601H
Takes 4-24" Bits
about $1600
Worksaver 500
Takes 6-12" Bits
about $1600
Frontier 300
Takes 6-30" Bits
about $2100
Land Pride PD 25
Takes 6-18" bits
about $2100
Again, these are priced with 2 bits and a stand included. I am leaning towards the Shaver, but a dealer has a Land Pride already in stock.
Has anyone used any of these brands? Any opinions?
   / Post Hole Digger #2
I picked up a Leinbach with a 9" auger. Will take pretty much any size auger as long as you have the HP to run it. Remember that the larger the bit the more HP is required.
   / Post Hole Digger #3
I can tell you from personal experience that the quality of the hole you drill will be in direct relation to the soil your drilling. Here in north Idaho a 9" drill works OK, but a 12" is a real pain in the $$$$ to use. most if not all small tractors don't have power down on the 3 point hitch, so they just tend to float over rocky or dry clay soils. Some makes (like my Speeco.. have a hydraulic down-force assist that helps. If your going to do this for a trade/business, most people use a front loader arm mount post hole digger that can be powered down, either on a skid-steer or a compact tractor. The skid-steers have higher hydraulic pressures and volumes to drive these units. Most tractors require a pto operated pump to power a front mount drill properly. There are some low volume drills available, but i don't know how well they work.
These front mounted units are kinda spendy though. If i had to do it all over again, i would have bought one years ago.
   / Post Hole Digger #4
I have a Land Pride PD35, the PD25s big brother. After putting a down pressure kit on it, it has dug all holes painlessly. I have 5 different bits ranging from 6" to 24" and all sizes work easily to full depth. My land pride info says that the PD25 handles 6"- 24" augers. I think that your dealer may be wrong about only going up to 18" with the PD25. ;)
   / Post Hole Digger #5
I have a Bush Hog 2102 with the stand. I have both a 9" auger and a 12" auger with Bearclaw replaceable teeth. It uses both these augers with ease. This is a heavy duty unit with the option to add hydraulic down pressure later if needed. Post Hole Digger 2102
   / Post Hole Digger #6
you probably have nicer soil than we have here. I have decomposed granite below 10" of the surface. Lucky dog. I just added my hydraulic assist, but havent drilled any holes with it yet....
   / Post Hole Digger #7
We do have nicer soil here. A big rock here is about the size of an apple and they are far and few between. I used to live along an old river bed. The post hole digger would go about 12" and the remaining 24" was dug by sledge hammer using a spud bar as a chisel. I don't miss that at all. I have spent a couple of hours digging each and every post hole.
   / Post Hole Digger #8
Yup...that sounds like my place. You should see the old auger i just replaced. about 1/2 of the metal has disappeared...warn away. My 9" holes were getting down to 6" diameters.
   / Post Hole Digger #9
I would have two friends standing on each side with a chain looped around the top of the spud bar to hold it straight while I hammered for hours with a sledge hammer. When we bought our new place non-rocky soil was at the top of my list. I put in 2,500 feet of new fence in the soft soil here by myself. It was so much easier I thought it was fun!
   / Post Hole Digger #10
I hate you...hehe.
It has taken me several years to fence and cross-fence my treed 20 acres. I have about 4,000 feet of field fencing in-place that Ive had to do all myself. I made a nice attachment that attached to my old JD tractor that held the rolls of field fence and they unrolled while i drove forwards..saved countless hours of work.
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
1987 FRUEHAUF 150BBL ALUMINUM TANKER TRAILER (A53843)
1987 FRUEHAUF...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
Generac S/A Towable Light Tower (A52377)
Generac S/A...
