Posthole Digger Post Hole Digger Warning
   / Post Hole Digger Warning #1
reasley
Just a reminder about the danger in using post hole diggers. I think that the most dangerous part of their use is simply getting off the tractor -- once you've done that, your about 60% of the way toward an accident.
Baylor alum and building namesake dies in farm accident
By Chad Shanks | Monday, July 20, 2009, 12:45 PM
Dr. Faber Francis McMullen Jr., a prominent retired Houston-area cardiologist who donated funds and art for the new Baylor faculty center named in his honor, died Sunday afternoon on his Grimes County ranch.
McMullen, 79, died when his clothing, likely a glove, became entangled in an auger when he was digging post holes for a fence, Grimes County Sheriff痴 Lt. Blake Jarvis said.
McMullen was found by his son, who lives across the street.
He was pronounced dead on the scene, Jarvis said.
McMullen, a Baylor College of Medicine graduate, met his wife, Roxana Connally, while both were Baylor students.
The 10.900 square foot McMullen-Connally Faculty Center was dedicated in October 2008.
   / Post Hole Digger Warning #2
Owning a tractor is inherently dangerous; we all know that. Once I got mine I looked at all the implements and wanted them all. After reading this website, I decided that
A) I won't use a post hole digger that much.
B) It's too dangerous
Received a call from a guy a week ago wanting some holes drilled- I explained to him the danger if that implement on a tractor outweighed me wanting one; he understood.
I do appreciate all the advise on this site...
   / Post Hole Digger Warning #3
A PHD isn’t all that dangerous, certainly no more so than a rotary cutter or anything else with spinning blades. But, if you get off the tractor while it’s running bad things can happen. I really can’t envision a situation in that I would get off the tractor with the PHD spinning. I really feel for the family, the son in particular.
   / Post Hole Digger Warning #4
It may have been one of the smaller gas posthole diggers, doesn't specify a tractor mounted unit.
All of these implements can be dangerous, I try to be careful but I'm not going to stop using them either.
Steve
   / Post Hole Digger Warning #5
A PHD isn稚 all that dangerous, certainly no more so than a rotary cutter or anything else with spinning blades. But, if you get off the tractor while it痴 running bad things can happen. I really can稚 envision a situation in that I would get off the tractor with the PHD spinning. I really feel for the family, the son in particular.
Right, I wouldn't get off the tractor either while the PHD auger is turning.
But frequently you see 2-person teams working a PHD, one on the tractor, the other on the ground trying to put extra down force on the auger via some jerry-rigged lever arrangement. That's risky IMHO.
If I ever need a PHD, I'd spend the extra bucks for a hydraulic-drive PHD that attaches to the FEL bucket. It's in front instead of behind for easier operation and you get downforce from the FEL hydraulics. Sure, you'd pay $2K for that hydraulic PHD rig versus $500 for a 3pt PHD, but that's cheaper than a visit to the ER or worse.
   / Post Hole Digger Warning #6
You can cut your hand off and bleed to death with a table saw. Sure some tools are more dangerous than others but somebody has to do the job. Common sense is the rule..
   / Post Hole Digger Warning #7
When i worked in the coalmines we would have to move the section up once a week, and that included the belt line... When we moved the belt-line, tailpiece and feeder we had to anchor the 'tailpiece' in the bottom, and that was solid rock.
The auger that was used had two hoses that connected to a piece of equipment,(a scoop)and the auger was hydraulic. It was best if two people held the auger because it would twist one person around.
Getting the hole started was the hardest problem because the anchor needed to be on an angle.. On one side of the auger was a lever that turned the auger on, and i remember when two workers was trying to get a hole started, and the guy on the side with the lever that turned it on was a green-hat.. The other guy was holding the 'auger steel' to get it in place and the new worker turned on the auger, and it twisted his arm around & broke his wrist, arm and shoulder... When we used the auger we always wore gloves.
When the 'new worker' turned on the auger he said he didn't know how to turn it off, and to turn it off you just raised your hand off the lever.. The boss was outside when this happened and said the new worker shouldn't have been running the auger.
It was a frightening thing to witness 6 miles underground.
I know this worker very well and his arm has 3 metal plates and 30 screws in it.
   / Post Hole Digger Warning #8
In our wonderful soil here (hard clay), I usually have to stand on the 3 pt arms to get it to dig in at all.
Hmmmm, I've been thinking of getting a skid steer. Keep talking about the dangers of a 3 pt PHD and maybe I'll have to get that skid steer with an auger to go with it.
   / Post Hole Digger Warning #9
I move my tractor back and forth a few inches while scratching through the hard clay. Makes a pretty sloppy hole on the top but it gives the auger less surface area to work on.
Eventually, the auger breaks through but it sure does eat the teeth up. Even my electric jack hammer struggles to break up the clay.
A quick disconnect hydraulic auger is on my list of "wants" to use with my front end loader on the tractor.
Bottom line, get off of the tractor, shut off the PTO.
   / Post Hole Digger Warning #10
hydraulic auger is nice on the tractor. seems like it would be safer, though that may be my imagination. But I cut the flow, and it stops. When somebody is "ground crew" for me, I use the switch deadman style.
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A51222)
2020 CHEVROLET...
2008 Mazda CX9 (A50324)
2008 Mazda CX9...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
