I haven't used my PHD for a while but it's been leaking oil through the four bolt flange where the input shaft goes into the gearbox. It's got a triple gasket arrangement which I am pretty sure is where the problem lies. What was in there were is a stack of three very thin gaskets - two thin metal (different thicknesses) and one super thin plastic.
Any suggestions on replacing that seal? I'm sure to order the parts from the manufacturer would probably cost more than they are worth and take a while to get to boot, if I can even find someone to order the correct parts. Is there an off-the-shelf replacement I might be able to get somewhere? They are just circular 4-3/4" O.D. and 3-1/8" I.D. with a 4 bolt pattern. Or could I just use a tube of make-a-gasket and bolt it back up?
