Post hole digger question
   / Post hole digger question #1
John32369
New London NC
Max 28
I'm in the the market for a post hole digger for my Max 28. What category implement works on these tractor? Would I need to buy one for a compact tractor or are they all the same?
   / Post hole digger question #2
I think an issue you will want to consider is the lift height and how high you can get the auger bit off the ground.
   / Post hole digger question #3
Category 1 hitch and implements, just watch ground clearance. However they do make them cuts and scuts, check out everything attachments. Free shipping if within 1000 miles.
   / Post hole digger question #4
If you've never used an auger:
Low rpm, shallow cuts, lift and clean the hop often.
Or
Get one of those 3-4' pipe wrenches and good gloves...
   / Post hole digger question #5
Or
YES - slow and lots of clearing of the bit. They are like a massive screw and lock in the ground quickly if allowed to go too deep with out clearing.
Also STAY AWAY FROM THE BIT when it is running (don't have some one guide it, etc) they will tear a person up VERY quickly!
   / Post hole digger question #7
I second the Everything Attachments recommendation. Give them a call and they should be able to answer all your questions. They're very helpful and won't steer you to something bigger or more expensive than what you actually need.
Do they make a post hole digger that will fit the Max 28?
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
Toro Workman Utility Cart (A51694)
Toro Workman...
2005 International 4300 Heil S/A Dump Truck (A50323)
2005 International...
2015 Jeep Cherokee Latitude SUV (A50324)
2015 Jeep Cherokee...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
