Post Hole Digger Help
   / Post Hole Digger Help #1
Steve3130
Northwest RI
Kubota 3130HST
I'm having trouble with the drive shaft on my post hole digger. I bought it used and the unit was stored outside. The problem I'm having is the driveshaft will not extend the reach the PTO. Seized up solid. I have been soaking it with penetrating oil and WD-40 for the better part of a week and still nothing. Any advice from the TBN Guru's. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Post Hole Digger Help #2
Don't force it........ get a bigger hammer..... /forums/images/graemlins/grin.gif
   / Post Hole Digger Help #3
Use PB Blaster instead of WD40. There is no comparison.
   / Post Hole Digger Help #4
It is my understanding that WD-40 is not a lubricant; it is a solvent. When a petroleum based lubricant has dried up and a semi-solid material remains, WD-40 will lower the viscosity and bring "new life" to the lubricant. If there was no dried out lubricant present, this chemical effect does not occur. If oil and WD-40 are applied together, the WD-40 will simply lower the viscosity of the oil. There are anti-seize compounds which will dissolve iron oxide (rust) and help break the seizure. I would recommend using this first, followed by a lubricant.
   / Post Hole Digger Help #5
</font><font color="blue" class="small">( I have used brake fluid as a penetrating oil and it works great. It was recommend to me to try by a auto junk yard. )</font>
It will also remove paint so be very careful on those surfaces you cherish.
</font><font color="blue" class="small">( It is my understanding that WD-40 is not a lubricant; it is a solvent)</font>
Both the WD-40 can and website call it a lubricant and penetrant with petroleum distillates. I know it is great for chasing water from ignition sytems and wires. However, based on my experience, it is not the best to loosen rusted parts.
WD-40 Website
PB Blaster, don't forget heat and sometimes a BFH are all needed for rusted parts.
regards,
Steve
   / Post Hole Digger Help #6
I once un-stuck a PTO shaft on a bush hog mower. This mower had literally sat unused outside for 20+ years! It was Grandpa's and too long a story to tell here.
Anyway, after he died, I needed to mow around the farmsted in prep for an auction. I hooked the 40HP Ford tractor to the new mower and was happy to see it did have blades on it!
The PTO shaft, however, was stuck solid! I hit it with penetrating oil and greased the shaft. Started hitting it with a BFH, but it wasn't budging.
I finally hooked a come-along to the PTO coupler on the mower, and with the mower on the tractor, hooked the other end to the front axle of the tractor and started tightening........... When I got it snug and under some pressure, then I moved to the mower and started applying "love taps"--actually wholloping it hard to finally break it loose.
When it came out, I cleaned the rust off of it, greased it up, and used it 2 weeks prior to the auction--then someone else owned it!
Ron
   / Post Hole Digger Help #7
Interesting. I don't think they actually list the exact chemicals in it. It obviously has solvent(s) in it to cut grease. I've seen it cut dried grease the way paint thinner will thin paint and bring stuff back to a good viscosity. I don't think the portion of the cocktail they call a "lubricant" is petroleum based. Seems I heard somewhere it has some compound that's graphite based which has somewhat spherical molecules that serve the function of a lubricant. A couple of mechanics have told me that it's not good to use it in car door locks because the solvent will completely cut the low viscosity lubricants in them and lead to drying and seizing within a couple of weeks.
   / Post Hole Digger Help #8
Gary E told me today that PB Blaster is what to use in situations like you have found yourself in. You can get it at NAPA. I was told it is far and away the best for penetrating rust and seized up parts. Try it. Nothing ventured, nothing gained. Good Luck
Thanks for the info. I bought some PB Blaster and a "Bigger Hammer". I'll let you know if it works. /forums/images/graemlins/grin.gif
   / Post Hole Digger Help #10
Steve,
I got an old Oliver wood lathe several years ago and the split pulley was "frozen".
After two weeks and a can of WD40 and a can of penetrating oil ? it was still frozen.
Got my old kerosene (electric blast) heater out and set the pulley close to the heat and let is get really warm (hot to the touch). Put on my welders gloves picked it up and the thing turned with just hand pressure.
You may have more trouble heating the full length of your shaft but maybe you could get a couple of heat sources and thay may do the trick.
Good luck. I like my Leinbach 12" PHD.
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
UNUSED AGT 3000 PSI HOT WATER PRESSURE (A51248)
UNUSED AGT 3000...
2019 Isuzu NRR Roll Off Truck, VIN # JALE5W169K7901549 (A51572)
2019 Isuzu NRR...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53472)
2022 MAXXD BD14...
2013 Ford Explorer SUV (A51694)
2013 Ford Explorer...
