Posthole Digger post hole digger for B7510
   / post hole digger for B7510 #1
moosetracks
West Central WV
Kubota B7610, Gravely L
Hi, I'm thinking about purchasing a Kubota B7510 (21 hp) tractor. Wondering if this will adequately power a 9" auger in clay soil with roots (2 to 3 feet deep). Any brand info would be appreciated. Landpride and bushhog are available from my dealer. Thanks
Moosetracks
   / post hole digger for B7510 #2
I have clay, no rocks, and use a Speeco PHD with a 24hp tractor that would be slighly more powerful than the B7510. No problems with digging or getting it stuck. Roots and rocks can complicate the issues. If you are doing a lot of holes, then buying an expensive PHD is probably a good idea. I think I've got about $550 spent on my PHD including both a 9" and 12" auger and have drilled over 100 holes with no problems. I would think the B7510 would be fine.
   / post hole digger for B7510 #3
Hey Moose,
Your 21 HP will be OK for pulling the auger, but lifting capacity is what matters most when digging holes. If the dirt is wet and sticky sometimes the auger doesn't want to come out of the hole. If you're careful not to let it "grab" and screw itself into the ground while digging in boggy ground you should be fine.
Gabby
btw, my horse's name is Moose. He's a big 'un. I'll post a picture if I can figure out how to do the thumbnail signature pic thing.
Thanks gabby. My soil is generally firm clay but not really wet most of the time. I've decided that tractor/implement buying is very confusing. Just working out the details of trying to get my first one and it's hard to decide what's right.
BTW, my italian spinone dog is named Moose, he's also pretty big but probably not as big as your Moose!!
Moosetracks
John Deere 260E DOBBS Off-Road Dump Truck (A50322)
John Deere 260E...
2015 Ford F150 Crew Cab Pickup (A50323)
2015 Ford F150...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
UNUSED MOWERKING QUICK ATTACH TRENCHER (A51244)
UNUSED MOWERKING...
