Post Hole Auger 2020
   / Post Hole Auger 2020 #1
jhendric
Bronze Member
Holly Springs, NC
none
Guys,
I've read many of the threads on PHDs, most are pretty old so I wanted to start a 2020 thread on PHD. I am presently looking at Tractor Supply and Agri supply. They are close in price, the Tractor Supply one is rated at 18-100 hp and the Agri is 25-65. This makes me think the TSC one will be beefier if it can support 100hp. I will be spinning a 9" auger into Central NC Clay and rock and I need over 120 holes for a fence. My budget in less than $1000. What do you think?
Here is the link to them:
TSC:
https://www.tractorsupply.com/tsc/product/countyline-3-point-post-hole-digger-602377#
AGS:
3 Point Post Hole Digger Frame With Gearbox | Agri Supply 69499
   / Post Hole Auger 2020 #2
I was going to get one to do some cross fencing for cattle. Then, I thought what would I do with it after that? :confused: Instead, I rented a skid steer with a PHD attachment. As I recall, it was about $200/day or less. I had the lines/holes marked and ready and I finished over a 100 holes in one day. Took the machine back the next morning. Spent the next week and half building fence. :rolleyes:
Forgot to mention:
None of the PHDs I've seen will work with a 3-point quick hitch. And with the cylinders I have now, it's not worth the hassle of removing for each use of the PHD. Don't know why the PHD needs it's own top link. :confused3:
   / Post Hole Auger 2020 #3
If you need 100 hp to dig a 10" hole, go with the plutonium. I can dig into hard clay at idle with my TSC PHD. The key ingredients are a sharp tip and sharp, properly positioned / angled cutting and shaving blades.
Because of the neck strain involved in post REPLACEMENT (the deer crash the fence), and because I picked up a hydraulic motor at an estate sale, I fabbed up a hydraulic driver and use my existing augers. I hang the digger off the left side of my bucket and use the curl lines to drive it. Flop the bucket to full drop, connect the lines and off to the races. It's mounted to the bucket via a male 2" trailer hitch and a 2 leg female insert with a pin in the motor cage (made up from scrap plate).
You don't need speed to dig a hole (this motor is about 60 rpm at above idle engine speed). but now reverse and down force is handy.
To be clear I don't need, or have, 100hp...my tractor is 40hp. My thought is the one rated for 100 should be beefier...I'll check my local Sunbelt Rentals, usually if I have to rent a tool 3 times the cost is about the same for me...that is for smaller dollar tools of course...
Confirmed on the rental. Skid Steer is $270 per day and the auger attachment is $100. I could buy the implement use it then sell it on Craigslist and come out better. IT's crazy how much people are getting for implements on CL here in NC.
   / Post Hole Auger 2020 #6
I didn't mean to imply you had a 100 hp tractor, its simply that the 100 hp gearbox, boom and U-bracket will be MUCH heavier than a 25 hp attachment. And ultimately you probably are going to have to lift it by hand to put it together.
What I would do is drill a shallow hole in a parking spot and disconnect it at that location with it in the ground. Otherwise it's a PITA to horse it around. That's why I went with the hydraulic method.
   / Post Hole Auger 2020 #8
Wow! That's outrageous! :eek: But for me, it's been around 10 years ago. I'm pretty sure it was around $200. I remember renting a backhoe for around $230. I put the dirt path I call my driveway in with a rented Galion grader from the same place. Seems like every time I went there I was handing over a $200 bill. ;)
   / Post Hole Auger 2020 #9
Nice job it using the high end rating of one implement and the low end of the other.
   / Post Hole Auger 2020 #10
Get the tractor supply PHD, because it looks stronger and you should have an easier time selling it. If its 100% clay your drilling, expect 15 to 18 holes per day. Any sandy content to your soil will greatly increase speed of drilling and auger extraction.
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
New Holland 477 Swather/Mower Conditioner (A52748)
New Holland 477...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 Chevrolet Cruze (A51694)
2014 Chevrolet...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
