Post Emissions tractors
   / Post Emissions tractors #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
I know this could turn into a lengthy post. But I’m really care more for a short answer. What are the issues with tractors made after the post emissions technology? Are they more troublesome? More complicated for the backyard mechanic? Lost their simplicity?
   / Post Emissions tractors #2
"What are the issues with tractors made after the post emissions technology?"
A big part of the emissions problems on tractors are actually caused by the operator. Either by not understanding exactly how these things work and how the tractor needs to be run to keep the DPF happy or by the dealers not teaching the owners how to properly run the tractors with DPF. Another big thing I suspect it happens a lot, is that people buy tractors too big for their application and can't simply put enough load on the engine to keep the DPF happy, however, this could be solved by going down the road every once in a while in the highest gear and RPM.
"Are they more troublesome?"
Maybe a little bit more, but mostly because these tractors do have a lot more electronics going on. And rodents are around, they can make a mess on the wiring.
"More complicated for the backyard mechanic? Lost their simplicity?"
Most are due to all the electronics going on, and specially ECUs that only the dealers can access those for diagnostics. So far I believe Branson is still the easiest tractor to work on as they retain the mechanical function as much as they can. The engine is still fully mechanical and so is the rest of the tractor. They only get the data logger for the DPF but that's pretty much a standalone unit and won't leave the tractor dead if something happens to it.
So basically it’s the extra electronics that people steer away from? What do the computer do? Run tractor a certain way once in a while? Can you use the tractor during this? I’d have to say, most times my tractor is only ramped up to 1200-1800 rpm doing very little but moving around. But of a load the other day shoveling dirt. Backhoe is a very light load too…my poor ole engine probably clogged…
   / Post Emissions tractors #4
The computer runs the entire engine as most manufacturers went with Common Rail engines. The other issue with this is that they tied the Emissions on the same computer. If a sensor or something electronic takes a dump, there you go, stuck with a tractor with no way to diagnostic or repair it, unless you start throwing parts at it till it gets fixed eventually, this a very expensive approach by the way.
Yes, you can use the tractor while it's doing the regen process. It's actually better as it will load the engine more and most likely do the process faster.
Keep in mind that there two types of emissions equipment, one is a DPF and the other is a DOC. The DPF will fill up to a point and then ask for the regen process. The DOC is constantly regening/burning once it gets to the temperature it needs, with this system is very important to run high RPM, otherwise it will clog and cause issues. The DPF is a bit more forgiving as the regen process can be forced as needed, while the DOC once it clogs, it's really clogs and has to be opened to be cleaned.
Mahindra likes to claim the their tractors don't have regen which is kind of false information because they use a DOC that is basically constantly regening or burning the particles.
I too run more or less on the same RPM range. I hate hearing the engines screaming just to move around the yard or do loader work. I'm glad I could buy a brand new tractor without all of these non sense. From 2021, it's now required to have emissions from tractors above 25 HP in Europe, it's called the Stage V and lead to all manufacturers having to relaunch some models to be Stage V ready and to discontinue a lot of other models.
Yes I couldn’t understand it. I bought the 2816. That changed to a 3016 but still had the same hp and engine. But after that it seemed like they were dropping the hp a little. Why was that?
   / Post Emissions tractors #6
Fuel needs to be kept cleaner on common-rail fuel systems than older diesel fuel systems. My neighbor's Tier lV tractor fuel system got water in the fuel tank causing fungus(algae) to grow. This caused tractor to receive new common-rail pump & injectors. On older style diesel fuel systems just drain the water or if more severe clean tank, add biocide to fuel in fuel tank,change fuel filters a few time & use tractor
   / Post Emissions tractors #7
That's the problem which I'm having. My tractor sets outside, although I do keep a tarp over the engine compartment. For the second time in 3 years I'm starting to have fuel problems. I do add biocide but hadn't been faithful about it for a while, as I kept forgetting to pick up a bottle while I was in town.
   / Post Emissions tractors #8
TYM which owns Branson uses the same Kukje engines as Branson does.
   / Post Emissions tractors #9
It’s also not a bad idea to run some additive in your ULSD.
Stanadyne, Power Service, etc.
Your injectors will live a lot longer and it may help prevent some fuel issues as well. The process of removing the sulfur“dries out” the
fuel. They’re supposed to use a
lubricity additive to replace it, but
I doubt that always happens…
The extremely high pressures in a
common rail system ( 10’s of thousands of psi ) really amplify the need for lubricity.
   / Post Emissions tractors #10
Yes, although Kukje still works pretty much as stand alone company making Branson tractors and some bigger JD 6 series tractors as well.
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
