I will likely be purchasing a post driver in the next two months and it looks like the Shaver HD-8 and HD-10 are in the price range for my needs. I have a JD 4300 HST, and it has 8.3 GPM output for implements. The HD-8 requires well under that and the HD-10 requires more. However, a call to Shaver's technical support confirms that the HD-10 will work fine -- the only difference will be recovery times and I probably won't notice a significant difference anyway. However, the HD-10 comes with a Cat 2 mounting bracket that would either require modification for my Cat 1 hitch or vice versa.
Some of my property has what is called "fractured rock" locally, meaning that there are basically rock pieces, but not a solid slab of rock (at least at posthole depths).
My question(s):
1. Has anyone used both? If so, will the HD-8, given enough blows, drive through fractured rock? How muuch estimated time per post?
2. Is the HD-10 (~71,000 lbs) significantly faster than the HD-8 (~30,000 lbs)?
3. Any additional observations about post drivers in general and possible alternatives that I may have missed that are <$4,000?
[Note that I already have a post hole digger.]
Thanks in advance!
My question(s):
Thanks in advance!
