Possible to dissolve "sludge" in spray tank?
   / Possible to dissolve "sludge" in spray tank? #1
rholmes69
Bronze Member
Zebulon, NC
Mahindra 2810
I have a 35 gallon pull behind spray tank that has about 20 gallons of mixed vegetation killer herbicide that has sludged up. My fault for not emptying it out before winter hit (the Kawasaki mule blew the water pump, so we couldn't put all the herbicide down), but it sat in the back of the pole barn and now has a sludgy film to it. when I hook up the pump, it will run for about a minute, then all the jostling will let the gunk get to the screen of the intake line and the pump loses pressure. I have to open the top, shake the intake line free of the goop and then briefly scrub the screen with a toothbrush. I don't want to just go dump 20 gallons of vegetation killer out on the property, is there any way to add something that will help dissolve the sludgy bits? Thanks in advance.
Pallet Fees (A50775)
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
