Oil & Fuel Possible purchase of M-F 50 diesel
   / Possible purchase of M-F 50 diesel #1
Chuck_Lind
Mahaffey, Pa.
2000 New Holland TN65 & 1956 John Deere 50
I'm about to purchase a used circa 1962 M-F 50 diesel with 3972 hours on it. It seems to run okay with the exception of running it up to about 2200+ rpm's; then it starts missing like a gasoline engine with worn-out spark plugs. There's no smoke or unusual sounds...just cutting in and out. Admittedly, it needs a new fuel filter, but it concerns me about the "missing" at operating speeds.
Any advice from you good folks?
Also, anything else I should be aware-of should I purchase this machine?
Thanks in advance...Chuck
   / Possible purchase of M-F 50 diesel #2
Chuck,Probably dirty partially clogged injector, also check air filter and as you said fuel filter,You can run some of that stuff everyone else suggests but I don't remember the name ?I'm sure someone will post it for me , BTW how is the power steering? good no leaks I hope..Happy tractoring /forums/images/graemlins/smile.gif
Thanks for the info...this machine has no power steering, which is okay because it will be a "backup" tractor for my NH TN65 and will also be used for raking hay, brush-hogging, etc.
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
John Deere 6175M (A50120)
John Deere 6175M...
2015 FREIGHTLINER M2 DAY CAB (A52141)
2015 FREIGHTLINER...
UNUSED FUTURE MINI SKID STEER HOLLOW WOOD GRABBER (A51244)
UNUSED FUTURE MINI...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Crane Service Truck (A50323)
2019 Ford F-350...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
