Grading Possible dozer purchase
   / Possible dozer purchase #1
pharmer phred
Frankfort, OH
Kubota 3080Mower; JD 5325, Kubota KX91 mini-excavator
I have a couple hundred acres of stumps and residue left from where they cut pine trees for pulp. The price of the land was right, but now I have a mess to clean up. The stumps are beginning to rot since the cutting was done about four years ago, but I need to get a dozer to get the land cleared for farming. I'm thinking that a small dozer (less than 100 hp) would be good for this. Does anyone have experience in this area? Suggestions? Should I rent or buy?
Thanks,
   / Possible dozer purchase #2
i would rent a dozer repair cost can be 10s of thousands if the tracks system is wear really badly or needs an engine final drive work tranny work ect i would rent a 943 series cat i had a 943 cat replace motor with a used one 4k that was back in 1990 replaced rails that the pads bolt to 10k in 1988
   / Possible dozer purchase #3
How big are the stumps ? We have white pine here. It can be any size up to 36" even 4 footers are found. The stumps are still solid after 10 years. That is why I ask.
I have a 70 hp 14,000 lb TD7G dozer. It will take out a stump. Especially if it was left high on purpose for removal. But still an 18" stumps can take quite a bit of work. 200 acres of big stumps cut close to the ground could take an awful long time with a small dozer.
If they are 6" stumps that is a lot different.
On big stumps I would rent an excavator to get them out then rent a dozer to rake the roots and level.
   / Possible dozer purchase #4
I think I would opt to rent a stump grinder. You could turn them into mulch and not have a bunch of stumps left over. Afterwards you could do like Gordon said, rent a dozer with a root rake.
   / Possible dozer purchase #5
I'd second a big excavator - rip the stumps out & pile for burning.
A dozer is gonna make a huge mess & wipe out your topsoil.
Use the dozer to push the burn pile tighter as it burns down.
A stump grinder is gonna make large mulch piles & kill any growth around it for a awhile.
   / Possible dozer purchase #6
I'd go for the excavator as well.
I do own a dozer. A old d3 to be exact. It will take out stumps, but its not the best tool for the job. A eight inch stump is a bit of work for it if the stump is cut low to the ground, at least in my clay soil. Its not gonna be just a push and go exercise with a small dozer. It will do the job, but its kind of like driving a 16 penny nail with a wrench.
   / Possible dozer purchase #7
Here's pretty much what I posted on another thread recently to a similar question - IMO: "nothing costs like a dozer can...." -
There's a lot of "cheap" dozers around & very few represent good value, add to that small dozers invariably cop more than their fair share of abuse being pushed into tasks usually well above their "weight" & the cost can soon escalate.
Also consider relative to their "output" it costs roughly the same to repair, maintain or replace undercarriage on anything up to c.D6/7 sized machines & for the uninitiated dozer ownership can quickly become a whole world of mega $'s & pain when the first major repair comes your way - make no mistake owner any dozer is a high cost exercise. We run earthmoving gear including dozers & traxcavators on our farms/commercial earthmoving operation & if there was anyway I could avoid dozer/traxcavator ownership I would, unfortunately for us it doesn't (just) make overall commerical sense.
Depending on what you're trying to achieve, c.200acres is a large job of making good a logging "mess", I'd suggest you may be far better off with an excavator in the c.12T (maybe up to say 20T) class: it'll dig up stumps quicker & far cheaper than small dozers & is a whole lot cheaper to run on a cost/hr basis, fit the excavator with a thumb or grab & you can stack a burn pile really easily (& move fairly large rocks around), with the added bonus is an excavator isn't going to tear your land up like a dozer & has much greater versatility - you'll also find reselling any excavator is generally easier than a fairly limited market for a small dozer.
Also running a dozer for the uninitiated might be fun for the first day but it's also a whole lot harder to master & whole a lot rougher on the operator than an excavator, & whilst bogging a dozer is quite easy, getting it "unstuck" is a major exercise, whereas unless you've tried to "walk on water" an excavator can usually self recover.
Operating a small & aged dozer within its design capability will work out close to 3hoours working to 1hours repairs/amaintenance (at best, start asking much more of an already aged machine & the costs/downtime are going to escalate quickly & exponentially - for c200 acres pop the stumps/stack with an excavator then if you want to cultivate the land use a contractor with a large dozer (min.D7) fitted with root rake (or better stiill contract out the whole job)
   / Possible dozer purchase #8
Quickest way and probably easiest would be to have a guy with a d8 or d9 that runs a shear come it and make cuts thru there. Then you buy a 14-20k lb dozer to do the clean up and push up piles. This is a tremendous amount of work! Lots of diesel and seat time. Sounds like fun but will be very rewarding.
Brett
   / Possible dozer purchase #9
Couldn't have said it better^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A50854)
2006 MACK CV...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
Electric Wheel Hyd. Dump Wagon (A50515)
Electric Wheel...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
