Traction Positraction on Case 480
   / Positraction on Case 480 #1
wukong
Panama City, FL
Case 480CK Construction King John Deere JD 400
My tractor has a round pedal under the right heel of the operator. When pressing the pedal down to the floor the mechanism will sometimes work. More often than not the devise fails to engage and a clicking sound is present. This occurs when the clutch is pressed down and the tractor is at full stop before engagement of the pedal and the clutch. Can this be fixed with some adjustment or will it need $$$$$.
   / Positraction on Case 480 #3
You don't say what model 480 you have, but I think they are all pretty similar. On my 480C hoe, the pedal would not depress any, at all. I checked underneath, and where the actuating rod goes through the cover housing, was rusted/corroded, bad enough it wouldn't rotate to activate. I removed it from the tractor, and soaked with penetrate (50/50 mix of Acetone & ATF but use what you have) and got it freed up. I coated where it goes through the housing with never-seize,and it has been working great ever since.
There are a couple springs in there that release it when you tap a brake, or change directions that need to be checked, to see if they are broken, but sound more like mine, and just needs cleaned & lubricated.
Here is a link to Case Construction with an exploded view of the diff. lock a 480. Official Case Construction Equipment Online Parts Store and Parts Look Up. Parts for Case Equipment and Construction Equipment. Parts Store for Case Wheel Loaders, Case Excavators, Case Skid Steers, Case Original Parts. Look at the bottom of the picture for the #8 actuating rod, and where it goes through cover housing #12. That is where it binds up.
If you remove the little round pedal, then like 6 bolts to remove the cover housing, you can do the clean up at your work bench. There is a jam nut under the pedal, I think it may take a 1/2", or 9/16" wrench you'll need to loosen to remove the pedal. I'm thinking I put a pipe wrench on the pedal to get it loose. You'll probably want another pipe wrench on the rod it's attached to, to keep it from turning, and possibly torquing the yoke on the other end.
   / Positraction on Case 480 #4
I've never heard it called positraction on a tractor!
Nice!!
Miles read : 112,969 (A50323)
Miles read ...
2017 INTERNATIONAL PRO STAR (A52472)
2017 INTERNATIONAL...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
2008 Chevrolet Impala 50th Anniversary Sedan (A51694)
2008 Chevrolet...
