Position control lever stuck in draft position on ford 2000
   / Position control lever stuck in draft position on ford 2000 #1
kdmitch
ford 2000 1968 deisel
I have 1968 ford 2000 3cylinder diesel. I was playing with the draft lever(directly under seat on right) it was in a vertical position.(Position control) I pushed it down (Draft), now I can't put it back up to vertical position I cannot control the up and down with my lift lever. Everything before was working fine.
If I press further down on the draft lever, it moves about an inch, and I can get lift by bringing the hydrolic control lever all the way up, but as soon as I let go of the draft lever it drops!
I'm going to order a repair manual, but does anyone know of a source of an exploded view of the hydraulics on this tractor online somewhere?
An exploded view of the hydraulics would help alot! I'm not really sure what constitutes the whole lift cover or how to remove it to see what linkage has come undone or needs to be replaced!
Thanks!
   / Position control lever stuck in draft position on ford 2000 #2
SCAMMER
Scammer?
   / Position control lever stuck in draft position on ford 2000 #4
https://webparts.pvassociates.net/cnh/webparts/main.php
Here is a link to the new holland parts site.
Search by the model # "2000", and look in the "hydraulic systems" section.
Its not a substitute for a manual, but it will at least give you a glimpse at the parts under the cover.
Thank You so much! This is exactly what I was looking for.
Appreciate it
TOOLBOX (A50854)
TOOLBOX (A50854)
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
2015 Chevrolet Impala Sedan (A49461)
2015 Chevrolet...
