Position Control Lever Issues - TC35A
   / Position Control Lever Issues - TC35A #1
nichord
Skiatook, OK
New Holland TC35A
Hey guys, pretty new to posting questions like this, but been on the forums for a while. I have a question about my NH TC35A. I bought this tractor used and don't know much about the history, other than the price was right for the tractors condition. Person I bought from had been using a really heavy brush hog on it for a couple years. The 3pt control lever is not working as a position lever. It is either up or down with a very tiny sweet spot in the middle where it will stop flow. There is not a draft control on the tractor. I think this issue stems from the linkage that controls the relief valve from shutting off at fully raised position - which should also track the position of the 3pt arms. The bracket where the nuts adjust the length was busted when I got the tractor. I made a new bracket for this, but when I went to install it, I realized it was probably going to just break again as the arm it mounts to doesn't move. Or at least it seems like it should move. The arm on the 3pt will move along with the 3pt travel, but does the other arm where the leakage attaches move to? If so, where do I start to figure out why it won't move. Tractor has around 970 hrs now. 730hrs when I bought it. It is becoming more and more of nuisance to leveling dirt etc. All fluid/filters were changed as soon as I got it. The 16LA FEL works great with full lift, so probably not a pump or pressure issue. Thanks for the help in advance.
   / Position Control Lever Issues - TC35A #2
Nicord, you'll have to remove the 3pt top cover and check out the internal linkage. The shaft going to the threaded rod adjusts the limits of travel on the hitch.
2008 Ford F-450 14FT Flatbed Truck (A51691)
2008 Ford F-450...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
