Posi - Lock on a BX2230
/ Posi - Lock on a BX2230 #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
Can anyone tell me, how do you know for sure the posi is engaged and then unengaged? I look at the pedal and the movement of the level on the rear end, but it moves only about an inch in the back. I tried a few burnouts in sand but both wheels dig in regardless if the posi-pedal is pressed.
/ Posi - Lock on a BX2230 #2
If it is locked it will not want to turn left or right
When you say it wont want to, does that mean it would be very difficult to turn left or right? I hit the pedal and I can still turn just fine. If I check it on dry pavement, would that be a better test?
/ Posi - Lock on a BX2230 #4
Yep, that's why the manual warns of poor steering on a hard surface. It should be the same feeling as an old 3-wheeler. With my R-1's, it steers pretty good anyway though. One thing I have noticed, but have not explored further, is that sometimes, usually while going pretty slow while engaging it, I can feel the pedel move a little more, solidly, after I have pushed all the way down ... as though a dog was "waiting" to engage then finally did. If you had it locked and turned really tight, if you could do it at all, the inside tire ought to scuff pretty good. Also, if it's under a load, I don't really know if it can disengage till the load relaxes. Dunno if any of that helps.
/ Posi - Lock on a BX2230 #5
chances are your not getting it to lock in then....on my 1800 the lock does not seem to go all the way down until I get a little slipage...try pushing it while in a turn if you are just checking. what way the wheeles are at differant speeds so things can line up. With the dif locked the tractor will want to go forward not to the left or right. once locked I sometimes have to back up a little to get it to unlock
If I check it on dry pavement...no no no no no no no ....you might break something
/ Posi - Lock on a BX2230 #6
Make some full turns on a soft surface and watch to see if the inside rear tire is "differentiating" or digging.
I've noticed on my BX, I have to hold down the lock pedal for a while and can feel the lock engage through the pedal. Disengagement also takes some time and sometimes a bit of reversing.
/ Posi - Lock on a BX2230 #7
I can tell when mine is engaged! When one rear wheel gets "light", it will spin and ground progress stops. Putting it in 4WD or engaging the diff lock fixes it and progress continues.
Enjoy!
ron
/ Posi - Lock on a BX2230 #8
Try engaging the diff lock and turning the wheels when the tractor is in 2WD. It should be less tendant to turn in 2WD with the differential locked together. In 4WD the front wheels just drag the front end in the direction they are pointing.
I can tell the difference with the diff lock on mine, but I live in sand not dirt, so it's more noticable.
edit - another good way to tell is by turning the wheels and engaging the diff lock while backing up. Backing up it turns more slowly than when going forward, again, in 2WD.
/ Posi - Lock on a BX2230 #9
Simple test that shouldn't tear up your yard or your equipment. Find an immovable object with loose ground around it... like a big tree in the woods. Hitch the tractor to it securely (log chain) and gently tug until you lose traction (Don't get a running start! /forums/images/graemlins/crazy.gif). You should be able to observe either one wheel spinning or two, depending on whether the diff lock is engaged.
/ Posi - Lock on a BX2230 #10
Please excuse my ignorance, I thought that you should not try to engage this until you stop completely, press the pedal, then start again? Correct?
/ Posi - Lock on a BX2230 #11
You should be stopped when shifting the diff lock into place, but once in place, you should see both wheels spinning in the above test. If only one spins, then it isn't engaged. That is what he is saying. Many times, I have thought that it was engaged, only to find that it wasn't. I looked under the floor board and was surprised to see the reason that the diff lock is so "spongy". It uses a flat piece of steel as a "spring" when you push it down. Guess that is so it will not be forced into position unless everything lines up. I have had it "grab" with my foot on the lock and I am just starting to move the hydro pedal. I don't find that I need it very often, as the 4 wheel drive is usually enough to get me out of anything that I get into. I avoid getting into mud holes with my tractor as some have pictured on the forums. Caution, like experience comes with age... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Posi - Lock on a BX2230 #12
Junk beat me to it. The spring steel bar prevents you from putting excess pressure on the Diff lock pins when they are not engaged.
See attachment
/ Posi - Lock on a BX2230 #13
I've only used it during the winter when getting the tractor stuck in the snow. You know when it's in because turning the tractor is impossible almost.
When you depress on the pedal and it engages it actually pulls the pedal a little lower towards the floorboard. You can feel this when it happens.
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
2015 K and K Systems Towable Solar Arrow Board (A61572)
2015 K and K...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A63569)
BG PF5 HIGH OUTPUT...
2016 CATERPILLAR  730C (A63569)
2016 CATERPILLAR...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
PROPANE TANK (A63569)
