Portable Millers
   / Portable Millers #1
Whatswrong
land of living sky
B434 ,V 700 and 1086
I was in Lloydminster Ab. this weekend, Sat. morning I saw 3 semi loads of portable Miller welders heading west ,presumably to a distributor in Edmonton area another sign the economy is supporting business . I had to search to see they are made in Saskatoon which I probably should have known.
   / Portable Millers #2
You're prob right about Edmonton. Highly unlikely they're headed for B. C. :)
Terry
   / Portable Millers #3
Maybe Arc Weld has them ordered for a wealthy customer. :confused3:
   / Portable Millers #4
Portables come out of the US but some Miller equipment like spool guns are made in Canada. Most likely headed to Alberta, possibly for one of the big rental outfits like Hertz or Red-D-Arc. Alberta is the largest market for welding in Canada and probably one of the biggest in the world. The oilfield is big business but the oil sands is HUGE. When they do expansions, they aren't in the millions, they're in the billions!:eek: I used to work at place that did chromium carbide overlay on pipe for oil sands slurry. They were always busy and 90% of their work was just for Syncrude. There are several other companies doing overlay as well but the place I worked had the only elbow welder in N. America (probably the world) that could weld the inside circumference while rolling the elbow at the same time. It was closely guarded and kept under sheets whenever visitors toured the plant. All employee's had to sign confidentiality agreements. Apparently cost $750,000 to develop but made more profit than anything else at the parent machine shop. It was pretty impressive and had to be exact to burn 7/64" open arc wire at about 600 amps with about an 1 1/4" weave on 20-24" curved pipe elbows. The pipe elbows had to be flat at all times while welding progressed and each revolution the welding head had to move over to put the next bead beside the deposited bead. The bad part was for the operator. He had to sit for hours and just watch the meters on the welder to make sure the volts and amps stayed within a certain range. One of the most boring jobs imaginable. Have heard of big projects that require 3000 or more welders.
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A53426)
2015 INTERNATIONAL...
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Serco 200F Log Loader (A52384)
Serco 200F Log...
