portable blaster from harbor freight.
   / portable blaster from harbor freight.
i use it in a spark plug abrasive cleaner i have.
   / portable blaster from harbor freight. #22
I haven't ever heard that the Glass beads are worse than Silica sand, but would be skeptical since glass contains Silica. I have never heard of "Black Beauty", but after a quick Google, it sounds as good as anything else.
It will depend on what your blasting and what type of finish you want, of course the finer the blast media, the smother the surface. I see Black Beauty has a medium to elite grade, so a nice range.
I copied and pasted from here Black Beauty® Abrasive (Boiler slag, Coal slag) from READE
Black Beautyï½® Abrasive Normal Chemical Composition:
Silicon Dioxide = 41-53%, Silicon Dioxide- Crystalline "Free Silica" Quartz= <0.1%, Aluminum oxide= 17-25%, Titanium dioxide= 0-2%, Iron Oxide (FeO)= 7-31%, Calcium oxide= 3-15%, Magnesium Oxide= 0-4%, Potassium Oxide= 0-3% and Sodium Oxide= 0.62%. Source= Harsco Minerals MSDS
If you have a hood, use a cross wind so it doesn't cavitate against your body and use your mask, i think you'll be fine for what your doing.
   / portable blaster from harbor freight. #23
You probably don't want to spend this much $$. But, I bought this
media ( glass beads ,etc,)machine about 15 yrs ago when I was into drag racing for cleaning engine parts. It does a very good job of cleaning just about any part
yep.. bit much.. :)
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
2012 CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
2012 CATERPILLAR...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
UNUSED IRANCH MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED IRANCH MINI...
