popular logs
   / popular logs #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i dug some post holes for a customer last week..he is building a pole barn and using popular logs about 16in across 14 ft long ..are this going to hold up in the ground ? he has pealed the bark off and is going to set them in concrete...anyone else done this ? if it works out i my have to try this..thanks for the help bruce sorry i was going to post this in the projects but i was asleep , apparently. sorry
   / popular logs #2
I'm assuming you mean Poplar, and, no, they won't last at *all*.
   / popular logs #3
I agree- they will rot quickly in the ground, especially with the concrete around them (which will hold in moisture).
   / popular logs #4
Poplar is a good source of lumber BUT NOT for outside like you're mentioning. They will rot in a very short time. Use locust or get treated other wise he'll be sorry.
   / popular logs #5
A neighbour made a beautiful poplar (maybe birch) woven twig/branch fence around his front yard about 2 years ago. It was a lot of work. Lasted two years and now it's all rotted and falling apart.
   / popular logs #6
another vote against. Poplar does not like water, and will not hold up. Will also probably engage in really interesting warping.
   / popular logs #7
Good Mornin Bruce,
I agree with all the other posters ! Poplar is one of the worst woods that he could have picked ! Talk him into a change if you can ! ;)
   / popular logs #8
+1 for the negative response on poplar...probably one of the worst choices he could make for the desired application..
   / popular logs
thanks for all the replys..POPULAR.. wow i knew i was tired but what was i thinking.. spelling it like that..I passed on all the info..to the customer...he thinks i am nuts ... i told him i had a barn with cedar post that has been here i know of 30 years...said he had already had his post and is going to use them...i told him i would come back in a year and dig some new post holes for the replacement barn,,he just laughed and said he will show me in a year ,,they will be fine... i tried.... sometimes you just got to walk away .... thanks again bruce
   / popular logs #10
Maybe tell him to stand the logs in a water solution of copper sulfate and let them soak up. That will treat them so they last longer.:D
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2012 Crane Carrier Low Entry Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
