Pony motor water pump shim question
   / Pony motor water pump shim question #1
chas036
johnson city, ny
JD720D
I have a 720 diesel with a pony motor and I am replacing the pony motor water pump with a rebuilt pump. When I removed the old pump, there was one paper shim behind it. So when I installed the new pump (without the cover so I could see the impeller), I put one shim and tightened it down. I tried to move the impeller with with hand, but I could not get any movement , no backlash what so ever. My question is, what is the purpose of the shims, and should I continue to add shims until I get a slight backlash when I try to move the impleller with my hand?
   / Pony motor water pump shim question #2
Add shims until you get a little backlash the replacement pump is not the same length from the mounting flange to the bevel gear.
2008 John Deere 608C combine head (A50657)
2008 John Deere...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
JOHN DEERE  EURO BUCKET (A52472)
JOHN DEERE EURO...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
