pond
   / pond #1
Anonymous Poster
Epic Contributor
just wondering if anyone has any knowledge off artiesen springs. seems like I opened one up putting in a beach for my daughter. We have about a 1/2acre pond,and I was scraping a shallow part of the pond with my fel cleaning it out a little bit. went back a couple days later and my ponds up about 6inches and going up.
   / pond #2
I sure wish I had that probem, my ponds are at least a foot low due to this #%& drought. I take it your pond is fed by underground springs and in which case you'll be fine as long as your overflow is sized properly.
   / pond
yeah I have another pond about 40ft away, I ran 40ft of 4inch black culvert tubeing. Do these springs level off or will I have too maintain an overflow. Ill probley just dig up my whole back yard and have a 2acre pond.
   / pond #4
jacamille:
In order for any spring to flow, it needs to be fed from an aquifer that is higher than the spring outlet -- to provide the hydraulic "head." However, the aquifer could be many miles away, or it could be just your local groundwater level. If you just punctured the "cap" on the local groundwater level, it may just rise to a point and then level off. If the spring is being fed by an aquifer some distance away and higher than the top of your dam, you could reach an overflow situation.
Any good pond design should include an overflow pipe and/or a well designed spillway to allow excess water to escape without washing out your dam. Otherwise, it will probably just be a matter of time until you get a "gully washer" thunderstorm or other big rain/snowmelt combination that fills the pond to the top of the dam. If you don't have a spillway designed to allow the excess water out without washing out the dam, you will end up with a mudhole instead of a pond.
I am not an engineer, but in my job I had to select sites for stock watering ponds (called "tanks", or "tanques" in the Southwest). The ones with poorly designed spillways and no overflow pipes eventually wash out and the cost and time spent for construction was wasted. If the volume of water held by the pond is significant, they can also cause downstream flooding problems when the dam washes out. Doesn't sound like your pond is big enough for that to be a concern.
Your local county extension agent or the Natural Resource Conservation Service (formerly the Soil Conservation Service) can probably provide advice and specifications for spillway construction.
Good luck. Just wish I had a spring on my property so I would have your problem.
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
