Pond Aeration
/ Pond Aeration #1
TheGreyRider
Bronze Member
Central Pennsylvania
Kubota 2920
I have a pond, about 1/2 to 3/4 acre. I would like to install some kind of aerator, but i really don't like the prices of bought aeration systems.
Does anyone know if I could build my own using a small air compressor, some hose and maybe some PVC pipe with holes drilled? Has anyone out there built or made something like this?
Please any input would be greatly appreciated.
/ Pond Aeration #2
I have seen a few people in this area use a electric sump pump and reduce down the discharge to create a fountain effect. Not sure if that would be enough on a pond that size. It counld be placed on a timer if needed.
/ Pond Aeration #3
In researching this subject, I came to the conclusion that the one item you should get is a decent airstone. Although you can just pump air into the pond without anything to difuse it, you'll get more effective aeration if you use an airstone.
I got lucky this spring and found a used Koenders Windmill nearby, and put it up the day before Easter on my smaller pond. I still need to extend the airline to get the airstone to the middle of the pond, but even with where it's currently located, I've had zero algae on that pond since getting the windmill up. I didn't want to have to run electricity to that pond, even though my barn is nearby, but also wasn't sure how effective the windmill would be. So far, I'll give it high marks, and the look of the setting with the windmill in place is an added bonus. It just looks right!
You may want to check this website for help:
The Pond Report > Ponds, Pond News, Pond Care, Pond Tips, Pond Building, Pond Stories
For my large pond, I'm still thinking of an electrical setup, so I'll be interested in what other TBNer's have for suggestions.
Good luck!
GGB
/ Pond Aeration #4
Pondboss.com also has allot of good info.
I had bought a rubber diffuser for one I was going to build, but the plans changed. The pump I was going to use , I believe was from Grainger, but I can't remember the details sorry.
The reason I was going with a commercial type air pump was the longevity vs a compressor. Wasn't my idea, but it was from the forums over at Pondboss for DIY.
/ Pond Aeration #6
That looks better than the one I was going to do 3 years ago, nice price on the pump too.
/ Pond Aeration
I am not all that concerned with the quality of the compressor as this will not be something that runs all day everyday. I will most likely put it on a timer and run it for an hour or two a night and this most likely wont run in the winter, only in the hot summer months.
I guess the biggest question is can i make a (diffuser) out of plastic PVC or is that something i need to buy?
My idea was to get a small electric compressor, run a hose to some kind of PVC piping with small holes and run air into it. I would mount it on the dock approx under about 5 or 6 feet of water.
/ Pond Aeration #8
I was going to make a diffuser at 1st, like you describe. I ended up buying a round rubber diffuser after doing more reading, (finer bubbles).
I also have read allot of post where guy's just used a soaker hose for a diffuser. That may be an option.
Just a thought
/ Pond Aeration #9
I use 2- 5' long pieces of 1/2" pvc pipe as my air diffuser with very small holes every 3" or so. It worked great for the last 3 years in my 5 acre pond, no fish kills through winter. I like the idea of a weighted soaker hose to spread the bubble effect over a large area. I got my used Thomas pump on ebay for less than a hundred dollars. So far so good.
/ Pond Aeration #10
FWIW, when I had a pond of similar size when I lived south of you in MD, I used a submersible (water) pump, it had a 2" outlet on it that I attached a 6' pvc pipe with a cap glued on the end that I drilled a bunch of holes in for a fountain effect. My pond was for swimming so my goal was to keep it from getting the slime/weeds. That "fountain" along with regular use of the blue dye kept it real nice. My pond was over 12' deep and by bringing up the cold water from below, it created a thermal cycle of some sort that worked well in my case. I used a upside down 5 gal. bucket with a hole drilled thru it with several small wheelbarrow inner tubes around the pipe and in the bucket for flotation of the pump, with a couple of cement blocks opposing sides of the pump to counter the rotational force of the pump. The water when hitting the surface created a lot of bubbles (oxygenate the water?) and the fish seemed to have no problem.
/ Pond Aeration #11
Good luck!
GGB
Our place in Maine has an old Windcharger wind generator. The Wincharger Corporation
It's in bad shape and I was going to throw it out but the link you provided points me to a DC powered aerator and we have a pond.
/ Pond Aeration
The next question is can i just use a small electric air compressor to get the air into the diffusers? If so does size of the compressor matter or is it more about air pressure adjustments?
Whether i buy or make a diffuser will a standard air compressor work?
/ Pond Aeration #13
Grayrider, There are allot of folks that use just a standard air compressor at least at first, so I would say yes.
I read one post a few years ago from a guy, that had a big compressor in his shop. He had a small pond behind the shop so he just plumbed a line to the pond with an inline shutoff. I think he used a soaker hose also?? not sure.
As far as A.C. size, that may be some trial and error with a particular compressor, you may find it will efficiently run one good diffuser, maybe 2. Also what kind of diffuser you use will effect how much air you need for it to work the way you want. ( that for me is why I looked at a dedicated pump system, the kinks have been worked out already)
Air is air and what ever delivery system you use is up to you. Allot of ponds are somewhat remote, so sometimes it's easier and more efficient to buy a small, cheap dedicated air pump.
/ Pond Aeration #14
Our city has a pond and it is kept aereated with what is called a ring compressor. (Low pressure high volumm.) It seems to do a good job and as far as I know has been trouble free for yrs.. The prices on these seem to run from 50$ used on E-Bay to very expensive.
Always wanted to test the discharge of a vacumm cleaner to see what depth/PSI they could overcome.
/ Pond Aeration
Well here is what i was thinking of doing, i just dont want to waste money if i dont need too.
Get a small Harbor Frieght compressor, maybe a 50-90 dollar compressor.
Connect the compressor to an outside outlet, with a cheap timer, the outlet is under an overhang from an out building so it is weather proof, and i am sure at this time hose is cheaper than wire.
Run the hose over to the pond, which is about 100ft maybe to the dock. The water depth at the dock is about 7ft, total pond depth is about 12ft.
either buy or make a diffuser and put it close to the dock, not under it.
Run the pump/compressor for about an hour every night.
would this work?
/ Pond Aeration #16
TheGreyRider, Your hose will freeze shut where it enters the water, in the winter.
Winter is the only time I run my aeration,once we have a good snow cover on the ice.
/ Pond Aeration
I dont plan on running this during the winter, only the hot summer months when new rainfall is low, and springs are running slow.
/ Pond Aeration #20
what is the average depth of pond, and shape of the pond?
what are you trying to achieve?
above info can dramatically change what might be suggested / done. a shallow lake, and wanting better oxygenated water, and better less black mud bottom. would more likely be better served in getting circulation going around the outside primeter of the lake. think whirl pool like current but much slower.
deeper lakes with same notation above, can be served better with air diffuser held off bottom about a foot.
general pond pumps for say backyard koi ponds can work. and are made for 24/7/365 day usage. though diaphragms style pumps you can except to replace diaphragms once a year or couple years. i never did keep trac of the better piston style air pumps. make a post at koiphen and you should get a few replies back of current good brane names. that are made to last.
if this is a breeding lake / growing fish lake. with high stocking levels. vs say a general catch what you can eat lake for your family. then you might be better setup with "air lift" setup. were you have pvc pipe going down to about a foot off bottom and about 1/2 foot below water. with an air diffuser 2 to 4 feet below surface of water and a string of these running down center of pond.
again it all depends on shape of lake, depth of lake. and what you are wanting achieve. remember ""current is the key"" majorty of the time if you are looking for better fish quality.
on a side note air compressors are a very bad thing to use. the motors on them are not meant to run constant. and can quickly over heat. and burn the motors out. i do not like say it, because it sounds like a sales pitch. but the better air pumps out there, are built to last, and use less electricity. that cheap air compressor might cost ya 20 bucks a month to run. vs say a good pump that might cost 300 bucks up front but only a couple bucks a month to run. above is overly stated, then again, i have seen some doozies, of what folks have done. and i might not be far off on some them.
but honestly if you start pricing out an air compressor motor i am guessing at most 6 months life span over a couple years plus the extra electricity using the motor vs a higher price good grade air pump meant to run 24/7 and the less electricity it uses. plus less hassles. do the math. is all i can say. to many folks been there done that. and have learned.
pondboss.com
koiphen.com (Koiphen.com)
if ya goto koiphen and goto construction forum. you can find multi ways of creating air diffusers. about anything that can be done DIY has been done there with guides. if not someone already in the know. for you i would say go for epdm style membrane diffuser disc. errr what is the rubber stuff made out of? ((been to long)) any hoots membrane diffusers, if ya do a search for "koi pond" or hit koiphen dealers, look at bottom drain diffusers. same like diffusers. that have a membrane. they will last longer and less likely to clog up if they clog up at all. compared to the stick diffusers or like air stones you might see in an aquarium.
pondboss.com seems like a smaller community and takes a little longer for responses to happen.
most pumps regardless if they are for a pool, pond, or other, need some sort of protection against the elements (wind, sun, cold, etc....) you can get say a black plastic bin, or cheap trash can. cut the top half off, flip it upside and over the pump. cut notchs / drill holes for power cord / air cord. then drill some holes around the bottom to allow air in.
if you do end up needing an air diffuser vs something else. pending on how far the diffuser is out in the lake. i might suggest paying the little extra for weighted air tubing. if not that, then figure out a way to keep that tubing sunk. if not fish pools, trolling motors, boat paddles / oars, legs / arms from swimming will get tangled up in the hose.
as far as actual air pump sizing and size of pipe to get. to many variables that tend to make things complicated for most folks. and with that. tend to tell folks to call some of the koiphen dealers. majorty of them have specs of air pumps on hand, along with a program to calculate info or some quick sheet charts. to size air pipe / hose, air pumps.
been there done that, i keep noting back at koiphen dealers, due to been part of koiphen for a long time. but more to the point local pool shops, nurseries, and like normally do not have people with the skills, knowledge, let alone experience for what ya asking. and if not koiphen dealers, then hit pondboss dealers. and in that trying to get ya in with correct folks, that get ya setup, if not with items, perhaps correct base line info. so you have something to go off of.
2002 Dodge Ram Crew Cab Pickup Truck (A61568)
2002 Dodge Ram...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A62131)
UNUSED WOLVERINE...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A62131)
UNUSED WOLVERINE...
