polyurea grease ?
   / polyurea grease ? #1
glgeek
Bronze Member
minnesota
X728
does anyone know if the John Deere SD Polyurea grease is Polyurea Shear Stable or Polyurea Conventional?
it appears that this is what JD used as factory fill, but i am thinking of using it in other applictaions as well which previously had Lithium.
TIA
   / polyurea grease ? #2
Well,JD makes both types of Polyurea grease,conventional and Lithium. Why not use both.:) I use the conventional on the tractor,and mower deck,and their moly grease on my loader.
Greg
   / polyurea grease ? #3
Wondered myself a while back, but I couldn't find anything that gave a definite answer. However, everything I read suggests that it is shear stable. The closest polyurea grease I found with similar specs was the Mobil Polyrex EP2, which specifically says is shear stable. In many deere manuals it says the preferred greases to use are the polyurea or Lithium HD. Would be surprised that they would suggest both greases if they weren't compatable.
I use the deere polyurea on my 2210 & on my father's X320. Very good grease. I do have another grease gun filled with Mystik JT6 hi-temp (lithium complex) for the u-joints on my truck. Depending on the application, having 2 grease guns isn't a big deal. There is a lot of good greases out there, but the best advice I was given was no matter what you use, frequent greasing is more important than the type. :thumbsup:
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
2025 Wolverine PFA-11-3300G 48in 3500lbs Hydraulic Adjustable Pallet Forks Skid Steer Attachment (A52378)
2025 Wolverine...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
