poly edge for BX2200
   / poly edge for BX2200 #1
rosey
Appomattox, Virginia (Central Va.)
Kubota BX2200
I know that this has been brought up in posts past but I thought that I would check again. Has anyone found a bolt on poly edge that would fit the LA211 loader on the BX2200?....if so where did you find it??...I'm tired of marking up my concrete driveway while pushing snow and wanted something other than having to bolt pieces of 2x4 to the loader as mentioned some time back on a post. Thanks
   / poly edge for BX2200 #2
I was looking at buying some HDPE sheets from McMaster Carr and making my own, but another poster pointed out that some of the composite deck boards are made from HDPE and would probably work just as well for a lot less money.
I have priced some of the boards locally and looks like it will be about $20 for a 5/4 x 6 x 12'. Heck that would give me 3 separate ones which would probably last several years.
I still have not bought one yet, as the one brand that said it was HDPE the company did not stock and the other brand I could not tell for sure. I will probably end up buying one anyhow, and see how it goes.
Might be an option to try.....
   / poly edge for BX2200 #3
My dealer had a poly edge they had a local company make up for the FEL. I think it was $75, I did not get it. But give them a call, Paul Histand Co in Doylestown, Pa 215-348-9041, ask for Mike. Let us know if you buy it and if it works.
20005 (A48082)
20005 (A48082)
2016 Ford F-150 Pickup Truck (A46684)
2016 Ford F-150...
Feed Bunk (A49339)
Feed Bunk (A49339)
Ingersol Rand Air Compressor (A49251)
Ingersol Rand Air...
12-16.5 SKS9 Tires (A49251)
12-16.5 SKS9 Tires...
LEUS XR3037 4WD Tractor (A49251)
LEUS XR3037 4WD...
