Pole Building Ideas?
   / Pole Building Ideas? #1
One Acre Farm
MD
I am moving my farm business to a long term lease property (think 7-10 years) and need to put up a small pole building/metal bldg. I have been doing some research on this site as well as the web in general and am getting some good ideas.
The building will be used as an office, a place to store tools, a place to keep storable vegetables, (onions, garlic etc) and a place to get out of the sun and eat lunch.
In terms of size, I am thinking 20x20 at the smallest, and perhaps as big as 24x32.
Some questions:
1. Since I know I will not be there forever, does it make sense to pay for a concrete floor or just use gravel?
2. Which type of building material is easier to take down and move?
3. Are there some types of styles that are move conducive to better work flow. For example, I am thinking a wider structure with 2 garage doors even if it is not as long is better then a narrow bldg with one door that is long so that tools do not get stuck in the way back never to be seen again.
Any ideas would be helpful.
   / Pole Building Ideas? #2
I have seen some metal buildings about the size you are talking about, that are the metal carports with ends and sides. They make them taller to accept garage doors and walkin doors. They go up quick and can been taken down and moved.
   / Pole Building Ideas? #3
Just a thought.
I suppose that property tax laws vary across counties/states, but in the county in which my farm is located (NC), carports/metal buildings that are not permanently attached are not subject to property taxes.
Steve
Edit -- Oops, just reread you post and saw that the building is going to be on leased property. I'm not sure about the property tax consequences for the lessor.
   / Pole Building Ideas? #4
Not sure where you live climate-wise, but would a poly-tarp style building work for you??
Check out HiQual, there very tough, cost effective, easy to erect, and one of their product lines can be dismantled in less than a day and taken away. There's no way to insulate them though.
-Jer.
   / Pole Building Ideas? #5
You may want to consider a ready made building. This is something you could pick up and move easily. I don't think you will like a gravel floor but you could set the building up so that concrete can be an option later.
   / Pole Building Ideas? #6
Some questions:
Take a look at the albums linked in my signature, I had a 24x36 built by a Amish/Mennonite company for about what I could by materials for. Where in MD are you?
   / Pole Building Ideas? #7
His web site says he has a CSA in montgomery county. I don't know what you have to do to put a taxable structure on rental property. I would go with a couple sheds on skids, one for an office and one for storage, so they can easily be moved later. I know a builder friend of mine converted a shed of his into his office, complete with sliding door, insulated, AC window unit, electric, etc.
   / Pole Building Ideas? #8
The first thing I'd do is communicate with the Owner/Landlord.
He might not support your idea - you might learn the landlord does not want any improvement on his land - he may not want the added tax burden - he may be reassessed depending on the circumstance(s).
If he does support your idea - he may require a certain type of structure which will then limit your options - he might only give you one choice - it might not be the choice you were leaning towards.
He may require that you show him paid receipts or release of liens. There are a few possible implications of a renter making improvements on land he does not own.
The other possibility is that he has had a similar idea of wanting a structure. He may pay for the material and let you pay for the labor. He will want the improvement left behind when you leave - but it might still be worth it (financially) for both of you.
If it were me - I'd start with communicating the idea with the Landlor/Owner. :thumbsup:
I would be interested to hear the name of the amish company you used, there are so many companies out there, if you know a good one, I would consider it first.
   / Pole Building Ideas? #10
If you looked through the albums, I have a close up picture of their sign.
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A55218)
2022 MAXXD BD14...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
