Pole Barns and Concrete Pads
   / Pole Barns and Concrete Pads #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
What is the recommended method for pouring a concrete floor under a pole barn? I'm still seriously considering building a 24'x40' barn and I am thinking it might make more since to use pressure-treated posts sunk 3' in the ground and pour the concrete around them for the floor. The outside of the "poles" could be used for the concrete form and the rest of the structure could be built over the floor.
I'm trying to reduce the amount of trenching, leveling and form construction, but am concerned about durability and longevity of the structure. Your experiences are appreciated.
   / Pole Barns and Concrete Pads #2
Set your posts and build the barn first. The ground doesn't have to be perfectly level but the barn does. Build it so the bottom stringer is high enough to give you the depth of concrete you want. Fill the barn ground level with "chips and dust", tamp it, and pour it.
   / Pole Barns and Concrete Pads #3
Not sure what it's called but the concrete stuff you put between the joints, wrap it around your poles to keep the concrete from touching the wood. When I told a buddy I was building a pole barn he told me to do this...but I'm too poor for concrete so I'll go dirt and then get some limestone.
   / Pole Barns and Concrete Pads #4
I prefer to build a floating slab and keep the lumber out of the ground.
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2014 JOHN DEERE 250D SERIES II OFF ROAD DUMP TRUCK (A52705)
2014 JOHN DEERE...
2021 New Holland C327 Compact Track Loader (A55218)
2021 New Holland...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
